wire for bga pads repair
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    hello guys, sometimes i need to fix some broken pads on some bga pcb. i tryed very different wire, copper wire. solder wick wire, but the result is always the same..... wires are too fragile and get destroyed after one or 2 movement of it.
    tryed alaos 0.002mm but it broke just by almost touch it with tips....
    generally i need to repair bga pads for 0.5mm so dont need a too small wire for it.
    any suggestion and where to buy it would be appreciated
    • 30985
    Re: wire for bga pads repair
    aliexpress, search iphone wire.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      tnx for reply. that one is ok?
      https://www.aliexpress.com/item/3305...chweb201603_55
      edit: im tring with a bigger copper wire like 0.1mm but my iron tips and my tweezers are way too big
      any suggestion for iron tips and tweezers?
      my soldering iron is atten 8586
        • 30985
        damn, that would need a microscope.
        the one i got is 0.02mm and still hard to see!
        cant advise on the iron as i dont know it, but obviously the smallest pointy tip you can find.
        dont use regular lead-free solder because copper wire will desolve into it.
        • llonen
          • Sep 2014
          • 495
          • hampshire
          I use between 0.02 and 0.05mm approx with microscope for BGA rework, as for soldering irons I use almost exclusively Pace rework systems. I do have a couple of Weller wsp 80's and for large thermal mass stuff I still use a hakko FR802 which I have been looking to replace with a Pace BGA rework station for some time now (been put off by unit cost and costs of replacement parts). For small thermal mass rework I use a Pace Thermojet which is ideal in every way.
          This all represents a significant investment, however a couple of repairs will usually pay for the kit, also I got lucky in that most of this was obtained on the second hand market and through workshop clearances. Additionally all the kit is like a generation before so is not new or current, with the exception of a couple of TD100 pace irons.
          • technicalspecialist
            Vintage fan repair, copper wire question
            by technicalspecialist
            I currently have a customer's vintage fan on the work bench to repair.
            It uses an induction motor with 4 poles. One of the poles is open.
            I couldn't find the break so i cut off the original wire.
            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
            The enamelled copper...
            03-16-2023, 12:54 PM
          • bussincaps
            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
            by bussincaps
            Hello All,
            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
            08-03-2023, 12:57 PM
          • wnlewis
            New wire for my RDE3340 Whirlpool electric range
            by wnlewis
            OK. I got the rocker switch figured out thanks to the good advice on this forum.
            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
            This is a Whirlpool RDE3340 electric range.
            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
            Where may I find parts...
            01-08-2025, 11:21 PM
          • abajor
            A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
            by abajor
            Like title says A2141 came in with Water Damage, customer desperately wants the data.
            The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
            I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
            That said after cleaning up the...
            12-21-2024, 07:16 PM
          • mikey5791
            Tiny Tech ATX480W output power ticking
            by mikey5791
            Hi to all forum members,
            ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
            Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
            02-20-2025, 01:11 AM
