NET 803A hot air station : handle problem
  • ICT Avatar
    • Mar 2019
    • Croatia
    I have an air leakage on the handle, with which glue or silicone it is good to seal air leakage?
    Handle model
    https://www.amazon.co.uk/Aoyue-Plast.../dp/B0123LX7FI
    master hoarder
    • May 2008
    • 12170
    Re: NET 803A hot air station : handle problem
    Is the air leak in a part of the handle that gets hot? If so, high temperature silicone or high temperature RTV glue should do the trick. If the leak is on a plastic part, and the part is made of ABS or PC plastic, you can use PVC glue (as PVC glue dissolves ABS and most PC plastics, making a very strong bond.)
    • yz7myg
      YU2MYG
      • Feb 2007
      • 18
      Kao što je Momaka napisao crveni silikon za automehaničare koji podnosi velike temperature.Ja sam skoro kupovao veliko pakovanje 10 Eura.
      • ICT Avatar
        • Mar 2019
        • Croatia
        I got a black silicon that goes up to 320°C . (seal good)
        I gave up the glue.
        So i can disassemble handle if i had to change the heater.
          master hoarder
          • May 2008
          • 12170
          Yep, that should do, I think. Same goes for the red automotive silicone that yz7myg suggested. Let us know how it goes.
          • ICT Avatar
            • Mar 2019
            • Croatia
            Repaired, seals great
            No air leakage
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • spleenharvester
              Making a Handskit hot air station a bit less stupid
              by spleenharvester
              I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
              I did not realise at the time of buying that its design is... interesting, to say...
              05-09-2024, 09:09 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
              HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
              This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-12-2024, 02:20 PM
