Help on desoldering transistor
  • shadow
    • Feb 2007
    • 732
    Re: Help on desoldering transistor
    I think a neat solution for cooling a passive graphics card would be to use the slot next to the graphics card for a slot mounted fan.
    Something like this Antec fan shown below.
    If the fan blows air into the case, it would be direct ambient air from outside the case. If the fan blows the air out, it will be expelled directly outside of the case.
    I just think that this is a neat solution.
    • Richie_asg1
      • Feb 2009
      • 21
      Could you use a low melting point solder instead - There is one listed at 145 degree ?
      Nice big blob - loads of flux and a jewlers screwdriver ?
      Just thought it would be cheapr than a chip quik kit.
      • Richie_asg1
        • Feb 2009
        • 21
        OOOhh.
        I fitted one of these from Maplin last year. I thought as it said "ball bearing" it would be fine.
        However - one year down the line my case was buzzing like box of bees - and it was because this fan had failed.
        I took it apart - and found - no ball bearing - just a bronze bush, which was now badly worn.
        If I had the money to spend, I would buy a new case with better cooling built in - and just transfer everything over.
        I did buy a fan speed controller for my case - and fitted a better case exhaust fan (salvaged) and opened up the lower part of the case to allow higher air throughput.
          03-31-2024, 02:12 PM
        • magneh
          Behringer Eurolive B205D repair - help identifying transistor
          by magneh
          Hello
          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
          Still, I need to replace this transistor....
          06-18-2025, 02:34 AM
        • elsomer
          help to identify transistor msi ms-15ck1
          by elsomer
          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
          02-17-2025, 05:30 PM
        • hans_meier
          HP EliteBook 840 G6 how to dump without desoldering
          by hans_meier
          I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
          01-04-2025, 04:11 PM
        • rddube
          Help with blowing transistor NAD T752 receiver
          by rddube
          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
          09-01-2022, 05:19 AM
