Zd-939l (main 939a-ver 4)
  • promo7uk
    • Aug 2014
    • 31
    • uk
    No heat at all from unit,
    replaced. Element in reflow hot air head end
    replaced bmt08 8amp 600v triac, nothing
    display just reads, error.. Nothing,, not even room temp 0.25 as it should start,, has anyone else had this purchased 2 of ebay. Faulty but brand new ,,, u can see never been opened, im now looking at bmt137 triac. As i have removed this next to optocoupler and still dead, doing the same., so maybe optocoupler or this triac, anyone else. Any info on these cheers, its duratool zd-939l
  • promo7uk
    • Aug 2014
    • 31
    • uk
    Re: Zd-939l (main 939a-ver 4)
    Found two issues and fixed,, old element temp core sensor was faulty. And wire from temp in element to main 939a ver4 board was faulty at crimp... On 2 of these just goes to show how crap they are,
      • 31265
      why crap? you got faulty returns - there are a huge number out there that work fine.
        • Jul 2011
        • 6070
        I have found the same thing with the company that makes these units there quality control has lot to be desired
        In the Desoldiering Gun units this sometimes can happen that the temperature sensor goes bad this also happens with the soldering irons as well
        The temperature controller board starts having problems controlling the temperature swings are wider to point that really can not use any more or the back light stops working or the switching power supply take a shit
          • Jul 2011
          • 6070
          Check and see if the the temperature controller is sending a 3 volt signal from the connector that only has two wires that go the optic sensor
          You do have to have the temperature on the display show 77*F or you will not have this 3 volt signal try powering a LED on those two wires
          If you do not get the 3 volt signal with the 77*F showing on the display then the temperature controller has taken a shit
          One note you can take the two wires that go to the temperature sensor and short then together
          BUT only do this to see if can get the 3 volt signal only you will not have any temperature control
          I have about ten of different types of units that all use the same temperature controller
          I have had to work on these units many times in the past
          If you need a new temperature controller board you can buy them on eBay also the heater element with the temperature sensor are available on ebay
          If you need any other information just ask me and I see if I can answer your questions
            • Jul 2011
            • 6070
            Were you able to fix your unit
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
            • semiRocket
              Toshiba 37bv701b power supply main rails
              by semiRocket
              The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
              I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
              Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
              10-26-2025, 01:55 AM
