Re: What is a good de-soldiering iron/tool?
The only controller that I find uses the “ T12 “ soldering iron tips
I would like to make my own or buy a controller board for the Xytronic soldering iron tips that I could set the temperature and read the temperature at the same time where would I find something like this
I have some “ T12 “ soldering iron tip but the controller just has a LED that flash’s when it at the temperature that is estimated but the handle to me feel it a little crap-e when holding it
It is very similar to this one but mine is all yellow in color
https://www.ebay.com/itm/HAKKO-FM-20...0AAOSwke9aEkcD
Well T12 is for soldering/simply melting solder, we're discussing desolder/removing solder!
Not much data out there about my ancient rework station, but I do know it's a 24-volt transformer based with op amp/triac based temperature control, so yes, simply using the zhong-di and don't connect the thermal sensor as mine doesn't use it (it uses resistance of the heating element - old cheap ancient design.)
Unfortunately that means that the thermal conductivity/mass of the tip is different so it might not work so well.
At least it does have the pump in the base similar to the newer units.Leave a comment:
fully aware of that.
weller used a thermister,
the zhong-di stuff uses a thermocouple.
that's fine - i want a digital display with presets rather than a pot and flashing led anyway!
plenty of controllers on ebay.
although i may build this one!
https://manolena.wordpress.com/2015/...tion-with-avr/Leave a comment:
Not all temperature sensors on these type of soldering irons are the same so if it has a temperature display might not work right just be aware of this
I know this because I have tried this and this did not work
I have a Xytronic soldering station I really do not like the temperature controller on this unit
I have a ZD-916 soldering station I really do not like the soldering iron on this unit
So I want to use the soldering iron of Xytronic on the ZD-916 but the temperature sensor is not compatible with the ZD-916 temperature controller so it gives an error messageLast edited by sam_sam_sam; 12-24-2017, 09:54 AM.Leave a comment:
Any comments about the 88-552A ZD-522 desolder gun?
I have a really ancient 4331 I think, had to replace the heating element once. I figure that if it dies again, it's way way obsolete and getting parts is virtually impossible now, retrofitting one of these guns would be cheaper... alas can't use the tips old gun... probably have to swap connectors, but hopefully the heat control is compatible enough (4331 is very primitive, this gun might actually be better quality but my controller probably can't utilize it...)
that said, it sounds similar to what i'm prepping to do.
i have a weller desoldering station with a dead iron,
so i got a zhongdi iron and intend to hook them together.
http://cpc.farnell.com/duratool/d007...5-7/dp/SD01394
btw, the complete units are cheap
http://cpc.farnell.com/duratool/d006...lug/dp/SD01384
but that would be no challenge/fun!Last edited by stj; 12-24-2017, 05:24 AM.Leave a comment:
Meh.
T12 irons/tips for the win. Nothing can beat their price/performance ratio. JBC has really good irons, stations, and desoldering equipment, but they are pricey. Like really $$. But good, though.Leave a comment:
I have a really ancient 4331 I think, had to replace the heating element once. I figure that if it dies again, it's way way obsolete and getting parts is virtually impossible now, retrofitting one of these guns would be cheaper... alas can't use the tips old gun... probably have to swap connectors, but hopefully the heat control is compatible enough (4331 is very primitive, this gun might actually be better quality but my controller probably can't utilize it...)Leave a comment:
the ac cord unplugs - it's just a "kettle lead" like on a pc.Leave a comment:
I seen that but there will not be enough cord left to change it around
and seeing how it has a grounded plug and it is grounded good inside the cabinet I do see a real problem with unless something goes wrong
I will grant it is not the way it should be doneLast edited by sam_sam_sam; 12-23-2017, 06:42 PM.Leave a comment:
the ac in or the dc out?Leave a comment:
I am going to get a zd915 for Christmas, so those links would be useful
I know you said you replaced the caps in it's PSU would you happen to have cap part numbers or specs? I will need to make sure the PSU is the same in this unit, but if they are that would be a time saver
Here is the link to the spare parts for the ZD-915 or ZD-917
https://www.ebay.com/itm/NEW-PLASTIC...53.m2749.l2649
I am not home right now but when I have some time I will post here for youLast edited by sam_sam_sam; 12-23-2017, 03:22 PM.Leave a comment:
wait till you open it, their are 2 different psu's
some have a switchmode and others have a transformer.
i dont know which is newer.
also, check the power cable with a meter - a few have been made with the wires crossed-over by mistake.Leave a comment:
I know you said you replaced the caps in it's PSU would you happen to have cap part numbers or specs? I will need to make sure the PSU is the same in this unit, but if they are that would be a time saverLeave a comment:
brick has 4 screws.
i have the schematics,
and photo's are on banggood.
sticker on the underside says 100-240v 50/60HzLeave a comment:
I use ZD915 all time when I run into trouble is when it is a multi layered board then I have to use a hot air controlled heat gun with very small nose tube to get the part out
Which is a ZD-982 hot air controlled gun but what I do not like about this unit is that it does not have a cool down mode which about to fix on my unit and that is to put a switch in line with the optic sensor to turn off the heater so then it will have a cool down modeLeave a comment:
no.
look a bit harder.
https://www.aliexpress.com/item/EU-P...786830474.htmlLeave a comment:
What is the voltage and amperage requirements for the gun (hoping i can use a ATX PSU), it would be nice to be able to use the tool to replace the caps in its own psu
@evilkitty:
Everyone is trying so hard to help you… but in the end it's up to you to make choices and move along.
After all the good, cheap and proven suggestions from everyone on previous posts
I do think it's time for you to get hands on the job, i.e., buy the tools and use them.
On the note of the Bakon 950D most of the ones i can find come with a T13 tip, are T12 also compatible?Leave a comment:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by ktmmotocrossI get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
