What is a good de-soldiering iron/tool?
Re: What is a good de-soldiering iron/tool?
From where the two red wires are to the yellow transformer on the same side of the red wires are the hot side the other side of the transformer is the low voltage side of the transformer no it was not a typo
I hope this helpsAttached Filesif you find these attachements useful please consider making a small donation to the site
the pump looks to get power from a black box mounted at the back of the unit (next to a under voluted 24v fan) that contains two 5w resistors and the low side of the pump goes to the gun
aside: really that fan grill is shit, either use a honeycomb design or cut big hole and use a cheap wire grill, wait a min this fan in a intake i thought it was exhaust
the only transformer i can find is on the power supplyComment
so with this component is there was nothing between it and the heat sync it would short 120v AC to earth ground?
If so how do the bolt threads not short it? Is the bold itself not conductive?Comment
Look in the black plastic box and see if there is a capacitor on that board if there is replace it as wellthe pump looks to get power from a black box mounted at the back of the unit (next to a under voluted 24v fan) that contains two 5w resistors and the low side of the pump goes to the gun
That fan grill is ok it moves enough air surprisingly enough it is the intake side of the fan
There is a very thin gray insulation pad on the back of that switching power supply regulator IC chip the one you circle in that photoLast edited by sam_sam_sam; 12-26-2017, 07:35 AM.Comment
There are two plastic washer one on the screw “head” is one that has a tapered ring that fit in the mounting hole to the heat sink on the chip side there is where the other plastic washer goes then the flat metal washer then the lock washer then the nutso with this component is there was nothing between it and the heat sync it would short 120v AC to earth ground?
Do not put the wrong plastic washer in the wrong side of the heat sink
When you put it back together check the screw that holds the power supply regulator IC chip that there is NO resistance between the screw and the heat sinkLast edited by sam_sam_sam; 12-26-2017, 08:02 AM.Comment
so when you say no resistance do you mean r=0.0000000 or r=N/C (infinite)There are two plastic washer one on the screw “head” is one that has a tapered ring that fit in the mounting hole to the heat sink on the chip side there is where the other plastic washer goes then the flat metal washer then the lock washer then the nut
that statement seems like a possible 0 == False vs 0 === False issueComment
so as for the 50v 10uf caps are low leakage Nichicon UKL good for those? UKL1H100KDDANATD (I have these on hand)
no need to replace the large 400v cap?
should i put some electrical tape on that bolt?
the bolt is in contact with the heat sync, none of the 5pins on the IC show a connection to the heat sync
I attached a couple pictures of how it looked whit the heat sync in its original state *i suck at editing so i tried to remove my legs as best i could cause i am not a attractive femaleAttached Filesif you find these attachements useful please consider making a small donation to the site
I forgot that this one had the metal bar that held all three IC chips in place
You do not have to do anything what you have with work just fine
I have work on so many different devices lately I guess mess up on this
These caps will be fine UKL1H100KDDANATD
The two 2200uf@35 volt caps are a FR series will be the only that will right
right now I cannot find the bag tag for those caps that I had used 3300@35 volts I will see if I can find the ones that I used
This will probably fit ( KY 2200uf@35 volt ) diameter 12.5mm
https://www.digikey.com/product-deta...1560-ND/756076
The 3300uf @ 35 volt one starts with 16.00mm which will not fit
I guess they do not have the 12.5mm anymoreLast edited by sam_sam_sam; 12-26-2017, 06:18 PM.Comment
May i ask why you linked a 25v cap?
anyway i found a FR cap
EEU-FR1V222L 2200uf 35v 12.5mm dia
EEU-FR1V471, i assume the 470uf should be upgraded to 35v also (otherwise i can use a EEU-FR1E471Y)
That bar only holds 2 of the 3 ICsComment
Try this one I have not used this series before “KYB” but I think it looks very similar to “KY”
This one is 2700@35 volts
https://www.digikey.com/products/en?...272MK40S&v=565
I going to buy some of these caps and try them in my units and see if it likes them or notLast edited by sam_sam_sam; 12-26-2017, 08:29 PM.Comment
I was comparing the size of what the 2200@25 volt diameter
I had put in the field 2200 ,3300uf and 25 , 35 volts
Then I did not look close enough what voltage they were
You could use that to this one 2700uf@35 volts EKYB350ELL272MK40S
Like I said earlier I would recap the temperature controller board you can reach the pins of the caps because the pins do not go very far on the other side board because of the LCD display
that is why the caps are not flush with the board
The easiest way to get the caps off the board is heat the pad and tilt the cap to one side then heat the other pad and gently pull out the cap from the board
Yes you want to upgrade it EEU-FR1V471
I know that because on the transformer version the winding are 24 volts and 10 or 9 volts
( To me the transformer version is some what better but use a 120 volt vacuum pump motor that does not last as long as the 24 volt vacuum pump motor but sometimes you have problem with the switching power supply so I do not know which one is better
I do side work for some one who has a few machines that have servo drive that I repair
So I have a few new spare Desoldiering gun units
I have had to retire a few of them so I have some spare parts to repair them the newer ones
The heater controller board has a +5 volts and -5 volts rails
The optic sensor has 3 volts if the version of the controller is not “ U3 “
You just put a switch and a white LED and a 100 ohm resistor in line to the optic sensor
So that when you first start the Desoldiering gun you just have the LED on and not the heater on the gun after the power supply powers up for 30 seconds then turn the heater on and turn off the LED
You will know if you have older version is when you turn it on it might turn off then turn right back on and might keep doing this a few times before it will stay on
The older version was used with the transformer the new version uses the switching power supply
The difference between the two is that older version the heater comes on right a way on the newer version there is a delay before the heater comes on
From what it looks like either they had a lot of the older controllers or they did not realize that you can not turn the heater on right a way so they wrote a new version of the program to fix this problem so some of the unit have this problemLast edited by sam_sam_sam; 12-26-2017, 09:48 PM.Comment
On the note of the EEU-FR1V222L vs EKYB350ELL272MK40S, the EKYB350ELL272MK40S does not show a ESR rating, [strike]till not sure when to to low esr and not to[/strike]; i assume a low esr cap will show have a esr rating
as for the temp control board, There are 2 boards in the front bezel you are talking about the top board rightLast edited by evilkitty; 12-27-2017, 05:59 AM. Reason: found the thread made a while back answering thatComment
what exactly is going on??
if this is new then you shouldnt mess with it till the warranty runs out.
btw, post a foto of the part of the gun that collects the solder - i want to see which type you have.Comment
Here is the pic of the gun
I would rather fix fatal flaws in the unit than deal with going though someone else for receipts and warranty process stuff
Also i would like to get have the caps needed to fix it along with all the other caps i need to order, so far i have about $30 worth of parts + shipping
this thing probably only has at most a 30 day policy on it anyway
I really do not want it to go down when i want to use it and have everything outAttached Filesif you find these attachements useful please consider making a small donation to the site
I personally do not like the way the glass ones are setup
If you do not have the thin metal disk and the filter and the so called spring in the right place you have no suction
With the plastic tube there is a place for the
spring and the filter and you very suction
That is my two cents worth on itLast edited by sam_sam_sam; 12-27-2017, 07:56 AM.Comment
on the old one the spring was hard to clear and you couldnt see in it.
the new one is similar to weller with the splash-shield at the back against the filter with a light spring holding it in place,
older weller instead of the spring, had an aluminium half-pipe running along the bottom of the tube - in some ways it was better.Comment
My old desolder gun uses a glass chamber, unfortunately I cracked it. Currently using a piece of kapton tape to seal it so it works fine. I need to source another glass chamber somehow...
... or if a new gun is cheaper... *sigh* likely need to make my own somehow.Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
by ktmmotocrossI get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
