Bakon 950D
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Bakon 950D
    Mine finally has a stand. A little/lots ghetto but it keeps it off the workbench.
      • 31198
      Re: Bakon 950D
      reminds me of the old antex irons!
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Bakon 950D
        They were yellow with hard plastic ridges in making a taper at the end. I still have mine around somewhere.
        It's a bit of solid core mains btw.
        When I get a bit of time i'll make something a bit sturdier with another to hold my hot air wand. It might be a while but i'll be back with something better.
          • 31198
          Re: Bakon 950D
          discovered those irons are for different tip series!!
          https://www.youtube.com/watch?v=QjgazZrmeLs
          • Fast Alpha
            • Feb 2013
            • 245
            Re: Bakon 950D
            Hello I bought this item, here are some photos, I got this from banggood website.
            How do I know which way to add the UK adapter for live and neutral. What if I get it mixed up.
            http://www.hse.gov.uk/pubns/indg305.pdf
              • 31198
              Re: Bakon 950D
              open the plug and see which pin has brown connected to it.
              or replace the plug.
              • Fast Alpha
                • Feb 2013
                • 245
                #27
                Re: Bakon 950D
                On the adapter thing it lists L and N. So that is Live and neutral.
                On the soldering station how do I know which is L and N there??
                  • 31198
                  Re: Bakon 950D
                  i just said, unscrew the cover on the european plug, brown is live.
                  • Fast Alpha
                    • Feb 2013
                    • 245
                    #29
                    Re: Bakon 950D
                    Can you use lead free solder with this iron.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      Re: Bakon 950D
                      It melts any kind of solder.
                      I bought one of the blade type tips and it's awesome for cleaning up when doing BGA reworking.
                      An update to the stand also. As ghetto as the last but working quite well. I just need to position it better as I managed to burn myself when adjusting the hot air.
                        • 31198
                        Re: Bakon 950D
                        lol
                        i also am working on a stand - once i find my "modesty blocks"
                        i'll probably post it in the "ghetto mods" thread once i'm done screwing it together.
                        i just ordered another tip too - that will make 7
                        • tmks2
                          Bakon 950d problem
                          by tmks2
                          I have a problem with the Bakon 950d soldering station. It worked for many years without a problem, now it warms up to the set temperature and displays the error S - E. I noticed that the MOSFET AOD425 reaches a very high temperature. Where could be the problem?...
                          04-06-2023, 05:24 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • definitely not an expert
                          iphone 11 ear piece module
                          by definitely not an expert
                          can anyone tell whether ive knackered this from the photos. In relation to black piece of something that appears to left in component in image with 156 at the end ?...
                          05-11-2025, 05:13 PM
                        • Th3_uN1Qu3
                          Bakon 950D "Extra Crispy" mod (19->24 Volt)
                          by Th3_uN1Qu3
                          Hello, you fine folks.
                          I've been hearing good things about the Bakon 950D (what a funny name!) soldering station with T12 tips (mistakenly labeled as T3 or T13, i see), so I thought i'd order one and a set of various tips.
                          The station arrived a couple weeks ago and I was pretty impressed with it, but I wondered if it could do just a little bit better. The replacement tips have arrived last week, just need to pick the package up. Anyway, on to the bacon (pun intended)!
                          I have noticed that it is usually labeled as 75W. Well, mine is labeled as 50W, so I...
                          08-26-2018, 01:55 PM
                        • Sudoer
                          DIYPHONE Store and AIXUN T420D
                          by Sudoer
                          I've seen enough reviews of AIXUN T420D on YouTube and decided to try it. One handle defective from the inside, ruined 3 JBC tips, just destroyed the plastic on the tips. One stand does not work, the soldering handle not drop the temperature. Because the seller refused to return the money, and AliExpress supported him and even PayPal did not help, I can disassemble this piece of shit and see what inside, if anyone is interested. The seller said that the station does not work with JBC handles, but I checked that it works. It's just a pity to connect the original handle to this shit. Beware of order...
                          05-04-2023, 04:55 AM
