Power Supply Tester
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Power Supply Tester
    Ok...in my quest for a BIOS chip, I ran across this little gem:
    http://www.biosman.com/Merchant2/mer...Category_Code=
    My gut feeling says its no good. To really test the PSU, wouldn't you want to put a load on it???? And then, wouldn't you need to somehow select the wattage of your PSU????
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Power Supply Tester
    That's just one of the old cheap testers in a new box.
    They have a load, just barely.
    Tends to be like a 10 to 20 ohm resistor.
    Just enough to make PSU stay on.
    They are fine for a quick checker to make sure a PSU isn't totally crap but they are in no way a load tester and they don't check ripple. (Just DC volts.)
    Mann-Made Global Warming.
    - Dr Seuss
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
      I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
      One other check that...
      08-03-2021, 06:41 PM
    • AJ847.63e
      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
      by AJ847.63e
      Hi Folks,
      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
      05-06-2025, 10:37 PM
      07-01-2024, 06:34 AM
