Re: Need software for Intelligent universal programmer lk48
Change offset 03CDD0 of the executable from 55 to C3.
http://www.aec.com.tw/10-48UXP-WINXP.htmLeave a comment:
why the fuck are you using the devil's "search" engine??
just go to the makers homepage!!
http://www.aec.com.tw/updatesw.htmLeave a comment:
You mention a fix for version 10.5 ...
Unfortunately, I can't find this version on google. If you have it, would it be possible to post a link or perhaps via PM?
Many ThanksLeave a comment:
not to my knowledge.
i think i'm the only person that even bothered - and the programmer was borrowed.
so i cant really do any newer versions with nothing to test on.Leave a comment:
Hello, Is there a license patch available for the current V12.40 Dataman 48UXP software? Many thanks for your assistanceLeave a comment:
Yes, no speed advantage on USB connection.Leave a comment:
I know that there are two versions (XP and UXP) of the programmer, the reason I am interested in an USB solution is just for convenience, NOT speed.
I asked about the PCMCIA and the USB2LPT because these seem two cheap solutions (if they work), then I noticed that the UXP uses the Cypress chip to add USB connectivity and asked if someone has more info about how it's connected internally.
I assumed it was used as an USB to parallel converter, so *possibly* it would be a simple matter to match the I/O pins from the chip to the parallel port signals.
However, as stj pointed out, the USB/Parallel capable software works ONLY on the UXP programmer, while the XP software (parallel capable only) works on both.Leave a comment:
no, the original UXP version has USB & parallel on the main board.
and works with both software versions.
they where offering the board as an upgrade for a while - but it has no speed advantage.Leave a comment:
And what about the USB2LPT (https://www-user.tu-chemnitz.de/~heh...index.en.htm)? Is it usable?
But anyway it wouldn't work, as the software would want an UXP to connect to.
1. The programmer parallel version connected thru an USB2LPT adapter to the computer USB port will still require the parallel software version (NOT the UXP version)!
That's easy to understand as the USB2LPT adapter will create a virtual LPT port!
2. If you bought the seller parallel to USB adapter kit, for an outrageous price if I do recall it correctly, then, and only then it would expect, and only work, with the UXP software version.
Although I stand for my opinion, I'm not claiming it would work or not,
but only sharing a light on the right approach to be taken.Last edited by megaraider; 03-22-2021, 05:33 PM.Leave a comment:
yes, the software is 2 different versions - usb, and parallel.
i only hacked the parallel - the programmer didnt have usb.
i have been told that the usb version is not any faster btw.Leave a comment:
you also need to know if the cypress has a custom VID/PID number in it's eepromLeave a comment:
No idea about the PCMCIA or the Cypress?
Does someone have an UXP and can map the CYpress chip connections (on the i/o side)?Leave a comment:
no idea - probably not because the software has the damned driver built-in.Leave a comment:
Does someone know if a PCMCIA (Not PCI-Express) parallel adapter works with the labtool software?
And what about the USB2LPT (https://www-user.tu-chemnitz.de/~heh...index.en.htm)? Is it usable? Seems to use the same Cypress device (CY7C68013A) that the UXP uses.Leave a comment:
it's not a fixed version, it's a patch.
download version 10.50 - it's the newest i cracked.
install it.
then open the exe in a hex editor and change the byte at location 0x01e433 from 55 to c3.
then save and your good.Leave a comment:
@stj: Could you send me the fixed software for the 48XP that is mentioned in the first page of thread? TIA.Leave a comment:
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by vinceroger69Hi has anyone got the latest software for the TL866CS MiniPro EPROM programmer version 03.2.86 is installed now i have tried the update site in the programmer software but it wont connect to their website i am running windows 10
Edit found this site programmer works now http://www.xgecu.com/EN/Index.html -
by Aurora256Hi everyone, does anyone use this programmer "T48 TL866II Plus High speed Universal Programmer"?
I am planning to buy a programmer for my Dell Precision 7710 to re-flash the bios....1 Photo -
by z1PoHi guys ,I'm looking for software related with this rare bios programmer.There is no any official site providing SW for that old board. Practically is (new) unused and unusable in that state without software
. Hope anybody know any info/software about it. Thanks in advance
Channel: BIOS Requests ONLY!
by SMDFleaAdding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
and once you do find them there`s a few crucial steps missing.
Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
After adding the chip save the xml file and copy it to the root directory of the...-
- Loading...
