USB-PD Sniffer for USB Type-C
  • japlytic
    • Oct 2005
    • 2086
    https://www.chromium.org/chromium-os/twinkie
    This is a product for monitoring current and voltage on a connected USB Type-C device, and it also analyses (as well as generates) data for the Control Channel (CC) lines.
  • G33RT
    Does the ISL95859C generates +5 volt at pin 34 ?
    by G33RT
    Does the Voltage Regulator ISL95859C supply +5 volt at pin 34 for the mosfet drivers or integrated Power Stages ?
    https://www.farnell.com/datasheets/3109343.pdf
    01-25-2023, 08:11 PM
  • noipi
    Mac Power Cable 3200s adapter
    by noipi
    i have a BY-3200s that i am using for typeC and other charging plug/cable for macbook laptops. i have a problem in typeC cable charger that cannot charge. i checked the IC(in the PICTURE) can anyone have a test tools like this, i cannot trace the IC code because it is scratch by the manufacturer i think. i attached the pictures. so someone can help me find the correct ic for this. i test it is shorted when installed. Please someone help me with the ic so i can order online. thank you. Sorry for my english i am asian...
    09-19-2025, 09:56 PM
  • caspian
    How can I modify An EC firmware?
    by caspian
    Dear members,
    I have an HP Elitebook 2540P laptop with mainboard: LA-5251P REV 1.0
    It has a SIO with model: SMSC KBC1098
    I think both the EC firmware and the main Bios reside in a single Bios chip.
    Problem: KBC1098 is partially defective so that it does not generate ADP_En at Pin 75 and generates 8 amber blinks on the charging LED, indicating some wrong input.
    Idea: Now I need to modify the EC firmware so that KBC1098 ignores the wrong input conditions and always generates a high ADP_En and does not enter a failure state.
    Is it possible...
    05-21-2024, 01:35 PM
  • totof
    Lenovo Ideapad 3 15ALC6 motherboard issue
    by totof
    I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
    Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
    When I opened it, I noticed three burnt components near...
    10-26-2025, 10:27 AM
  • jasko_jacker
    LA-L191P missing +3VLP
    by jasko_jacker
    Hi, all
    LA-L191P BQ24781 signals pin 28 -> 19V [VCC], pin 5 -> 3.3V [ACOK] pin 6 [ACDET] 2.6V, pin 24 -> 5.3V [REGN], pin 25 -> 5.3V [BTST] ,
    missing +3VLP -> EC -> signals for manage BQ24781. In the power sequence the +3VLP is the first signal in AC mode.
    I presume that the bios is working because one time the motherboard generate +3VLP and goes ON but after a shutdown the situation
    came back to no power on -> no main 19V. The question is: who generates +3VLP which is the basis of all other signals?
    Every time with the BQ24780S it's like...
    09-16-2025, 01:29 PM
