LA-L191P missing +3VLP
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Hi, all
    LA-L191P BQ24781 signals pin 28 -> 19V [VCC], pin 5 -> 3.3V [ACOK] pin 6 [ACDET] 2.6V, pin 24 -> 5.3V [REGN], pin 25 -> 5.3V [BTST] ,
    missing +3VLP -> EC -> signals for manage BQ24781. In the power sequence the +3VLP is the first signal in AC mode.
    I presume that the bios is working because one time the motherboard generate +3VLP and goes ON but after a shutdown the situation
    came back to no power on -> no main 19V. The question is: who generates +3VLP which is the basis of all other signals?
    Every time with the BQ24780S it's like starting from scratch, is +3VLP essential for the BQ?
    Schematic & boardview - https://www.badcaps.net/forum/troubl...-g53g-la-l191p
    Many thanks
  • mon2
    • Dec 2019
    • 14685
    See attached. These 2 resistors enable the LDO rails.
      • 21986
      looks like PU301 .+19VB -> PR301 -> ENLDO_3V5V -> PU301,PU501
      • ugamazing
        820-02020 PPBUS_AON missing
        by ugamazing
        Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
        Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
        02-05-2025, 04:21 PM
      • Destroyer-Br
        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
        by Destroyer-Br
        I'm working on an Acer Nitro 5 unit with the following specs:
        • Motherboard: LA-J871P Rev: 1B
        • Model: Acer AN515-55-59MT
        • S/N: NHQ7JAL00403906A973400
        • SNID: 03902728734
        Initial Issue
        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
        04-17-2025, 08:18 PM
      • jpreza
        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
        by jpreza
        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
        Looking at the card, it appears to be missing the following:
        1x 1.0uH inductor - orange square
        2x...
        11-01-2024, 10:54 PM
      • gurj1979
        Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
        by gurj1979
        Hey guys.
        Need help with this one.
        Fan not spinning due to missing PWN Fan signal.
        Also 5 seconds from powering up it freezes, unless in BIOS.
        But as soon as Windows starts to load, it will freeze.
        CPU is COLD / Room temp when it freezes.
        I've replaced the CPU, same problem.
        Replaced SIO/KBC IT8987e and reprogrammed - same problem.
        Replaced fan - same problem.
        Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
        Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
        08-19-2024, 05:22 PM
      • ein_individuum
        Missing Capacitator Intel I9-12900KF CPU
        by ein_individuum
        I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
        I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
        Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
        08-06-2025, 01:36 AM
