hi guys i want to hard wire my broken--tom tom one gps..
  • cadar21
    • Oct 2010
    • 53
    i bought this gps at the swapmeet for 1$....
    the dc port wont work an the usb port is missing...
    looks like somebody tried to fix it before me an failed....
    I used a battery from another tom tom gps to turn it on ..and it worked ..
    so i want to hard wire this gps to the cigarette lighter cable...
    i dont want to buy new parts to fix it... im just looking for the quick fix...
    id appreciate any help...
  • federalhouse
    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
    by federalhouse
    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
    **Background:**
    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
    **What I've Tried So Far:**
    1. I accessed
    08-01-2024, 07:03 PM
  • ash91
    Hp pavilion 15 not detect hard drive
    by ash91
    Hello gentelmen .... this is my first post and sorry for my bad english,
    so my proplem is my laptop keep losing hard drive even if i but the
    hard disk in the cady (the box that can replace the dvd rom with hard disk)
    when i turn the laptop on the massage that said no boot media found pop on
    the hard disk is fine and to be sure i try another hard
    i also update my bios to the last update
    the 5 volt is present on the hard connector on the motherboard
    the dvd rom work fine when i but a windows dvd in it
    also when i boot from flash...
    06-07-2023, 01:45 PM
  • wnlewis
    New wire for my RDE3340 Whirlpool electric range
    by wnlewis
    OK. I got the rocker switch figured out thanks to the good advice on this forum.
    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
    This is a Whirlpool RDE3340 electric range.
    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
    Where may I find parts...
    01-08-2025, 11:21 PM
  • madura2010
    DAY11AM6E0 hard disk drive and optical disk drive not detected
    by madura2010
    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
    i checked the connectivity of ribbon=good communication with hard and motherboard
    changed hard disk and checked=3f0 error persist
    sata power=+5v available
    Then checked data capacitors=all good
    Then checked data lines path connectivity to pch=all good
    reflashed...
    03-12-2023, 09:09 AM
  • emeskay
    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
    by emeskay
    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
    08-06-2024, 07:13 AM
