HDMI port replacement on Radeon 4650 advice
  • lucidbarrier
    • Jul 2012
    • 84
    I tried like heck to get the solder out of those tiny pins on the HDMI port. I used flux, a wick etc. I finally learned about Fast Chip (or ChipQuick) and bought some. I slathered some on and then pressed gently on the pins with the flat side of the chisel tip and they went through cleanly. It was amazing how nicely it worked.
    I cleared the two large holes that secure it to the PCB using the dental pick method that I learned from you all. The little tiny holes are a different story.
    How would you all recommend clearing those holes? There are 19 tiny holes. Should I slather some more Fast Chip stuff on and push the pins through and then wick it up or is there some other method that you all use?
    Which brings me to my next question, how do you get solder on to each pin? I've replaced caps on motherboards and displays and even an Xbox 360 but there is always spacing between pins. I haven't been able to find many videos on this kind of thing because there are mostly SMD videos now.
    • 30998
    Re: HDMI port replacement on Radeon 4650 advice
    prop it up, and use an iron on one side and a desoldering pump on the other side.
    • lucidbarrier
      • Jul 2012
      • 84
      I tried to use a solder sucker and the holes are just too small to get it to work just right. I do have a desoldering iron somewhere but I was starting to get worried about messing up the vias. I used the pick but I kept melting the solder from the other adjacent holes.
      I had wiped off that fast chip on the sponge and just sopped it up with the iron today and made a little puddle over the pin holes. I pushed the hdmi port right through with like no resistance. This stuff really is amazing. It was kind of a pain to wick up the stuff, and make sure that none of the pins were bridging. I really wasn't expecting this to actually work.
      Some of the pins were a little empty so I touched them up with regular solder. I made sure the two metal pins that secure it in place were soldered in with regular rosin core. I inserted it into my computer, expecting graphical glitches or something but it booted right up and has been running for hours.
      I really need to spend the money on a temperature regulated station and some various tips. My Weller SP40N 40W iron has been a really good workhorse but I like the iron nice and hot and it kills the tips.
        • 30998
        it does sound like your iron tip is too large.
        • flocko
          • Nov 2012
          • 1121
          A fine sewing machine needle is a must for your toolbox with a 5 amp connector block screwed to the flat end, to save your fingers getting burnt, same as a dental pick but a lot finer for the smaller holes. always works for me Flocko
          • bussincaps
            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
            by bussincaps
            Hello All,
            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
            08-03-2023, 12:57 PM
          • rustinjust
            technika tv, 32 inch,capacitor replacement question, useful advice needed
            by rustinjust
            I have a technika tv, 32 inch, around 10 years or so in age and last night when watching tv i heard a hissing sound and the next thing i saw smoke coming out the back of the tv, i instantly unplugged the tv. I took the back off tv to expose power board, then plugged in tv and saw smoke coming out of a capacitor, i will try and attach a photo below, see below for attachments of board and cap, and keep reading, maybe you can advise ?
            The cap says on it: 105kj450mff4. This doesn't mean a lot to me as i'm an amateur when it comes to electronics, though i've undertaken some repairs such...
            06-07-2022, 08:29 AM
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
          • Cysko
            Lenovo IdeaPad Gaming 3 15ARH05 not charging after repair
            by Cysko
            Hello everybody,
            One of my friends brought me his brother's laptop to repair, I'm the third person who put the hands on this laptop (he tried to convince his brother to take it to me for the ram upgrade, dust cleanup and thermal paste replacement but he wanted to make it to his university friend... sorry if I say that, but we saw the result).
            The laptop is a Lenovo IdeaPad Gaming 3 15ARH05 with AMD Ryzen CPU and Nvidia GPU.
            I'm going to give a quick recap of what happened before I got this laptop for repair to make clear the situation.
            A friend of his brother...
            11-24-2024, 07:30 PM
