Lenovo IdeaPad Gaming 3 15ARH05 not charging after repair
  • Cysko
    • Dec 2021
    • 7
    • italy
    Hello everybody,
    One of my friends brought me his brother's laptop to repair, I'm the third person who put the hands on this laptop (he tried to convince his brother to take it to me for the ram upgrade, dust cleanup and thermal paste replacement but he wanted to make it to his university friend... sorry if I say that, but we saw the result).
    The laptop is a Lenovo IdeaPad Gaming 3 15ARH05 with AMD Ryzen CPU and Nvidia GPU.
    I'm going to give a quick recap of what happened before I got this laptop for repair to make clear the situation.
    A friend of his brother tried to make a ram modules upgrade, his friend said it booted up correctly but it suddenly turned off (by checking on the event viewer, it was installing Win11 updates). It didn't power on again, and power/charging leds were dead.
    They after reinstalled original ddr4 ram modules because they thought it was something about ram compatibility. No power/charging even with original ram modules installed.
    Another person checked it a said it was a charger problem (he didn't see the +20.5V), he also cut in half the charger cable to check voltages (i still don't understand WHY he did cut the cable) and then he tried to solder the cable back.
    After all of that, my friend took his brother's laptop and gave it to me for the repair.
    I repaired the charger cable, tested and it works, so I removed the solder and crimped the cable back to make a better connection.
    The battery at this point had an output of 0.14V.
    Then I checked the motherboard and quickly found a shorted capacitor on the CPU power rail (capcitor PC3001). I replaced it with another one from another board and the motherboard now power on again.
    After power on, the battery had output of 10,1V (so the battery internal circuit protected it from power rail short)
    Another problem which I can't find the solution is that the battery doesn't charge.
    I checked the capacitors and mosfet near the battery connector area and noticed that the mosfet PQ104 receive the +20,5V on Drain pins but it doesn't make any output when battery is connected (I read the actual battery voltage, 9.7V right now).
    With battery disconnected, on PQ104 I read: Drain +20,5V, Source 4.2V, Gate 5.4V
    There is another mosfet, PQ105, that doesn't have any output power, I read 0V on both gate and source pins. the gate pins are connected to the source pins of PQ104.
    I'm sure I'm missing something, but I don't know what (another short?). Anyone has any advice?
    I already have the boardview and schematics (I found them here in the forum), but both boardview and schematics refer to the rev 0.2 motherboard. in this specific laptop I found the rev 1.0 motherboard (there are minor differences between the two revs).
    Thank you to anyone who will help.
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Hi, what is motherboard code?
    • reformatt
      • Feb 2020
      • 1507
      PQ101 or PQ102 will likely be shorted. Quite common after a main power rail short. BQ IC will disable charging in that event.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Nm-D191?
        • piernov
          • Jan 2016
          • 4439
          • France
          https://www.badcaps.net/forum/troubl...arging-circuit
          • Cysko
            • Dec 2021
            • 7
            • italy
            Nm-D191?
            it's NM-D191 GY535/GY536, Rev 1.0
            I'll check for short on them and i'll tell write what i'll find.
            i'll check also this, thank you!
            • Cysko
              • Dec 2021
              • 7
              • italy
              PQ101 and PQ102 not shorted, if they were shorted, the laptop won't power on now.
              It powers on and boot to windows correctly, but battery doesn't charge.
              • Cysko
                • Dec 2021
                • 7
                • italy
                After a closer inspection I found a short on PU101, pin #23 (connect to the gate of PQ105) and pin #22 (GND). I didn't notice it before!
                Removed the short, now it charges the battery!
                Now I'll test the laptop using some stress tests and then I'll give it back to the owner.
                Thank you anyway. I'll keep in my bookmarks the link about how to check the charging circuit because I think it could be useful in the future.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Nice to know u fixed it but your assumption on post#7 is not correct. A shorted dc-in fet will allow 20V to pass thru to CLR and mb will still power on but will not charge.
                  • Devaang Trivedi
                    • May 2025
                    • India
                    This re 7e ic is heating when I connect the battery and laptop isn't turning on neither taking power from the dc power jack
                      Lenovo IdeaPad Gaming 3 15ARH05 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad Gaming 3 15ARH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ARH05 boardview and Gaming 3 15ARH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 10:20 PM
                      Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                      09-07-2024, 05:20 AM
                      Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 05:00 AM
                      Lenovo IdeaPad Gaming 3 Notebook Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad Gaming 3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 boardview and Gaming 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                      09-07-2024, 07:20 AM
                      09-07-2024, 07:19 AM
