Considering purchasing a Logic Analyzer
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Re: Considering purchasing a Logic Analyzer
    OMG! I'm so excited! I got the 500MHz bandwidth 2 Gigasamples / second two channel digitizing storage oscilloscope module! Ebay wanted anywhere from 500$ to 1000$ for them but this guy was selling one as is because he couldn't get the triggering to work on it. He said all he did to test was hook it up to his signal generator. I've already downloaded the service manual for it but I'm hoping it's going to be some as simple as it just needs calibrating! I see in the user manual, there's a calibration routine for the triggering stuff. He wanted 150$ + 20$ shipping, I offered 75$, he counter offered 115$, I took it and went for the faster but cheaper shipping (USPS was cheaper and faster than UPS ground) and I paid a total of around 127$ for it!!!!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      Sounds good, if you can get it going.
      For the record, I bought a $20 USB one (LCSoft Devboard\knockoff) and built my own input protection board. I use the Sigrok\Pulseview software in Linux. It doesn't always work perfectly, but it has been quite useful so far. I would like to get something better one day but for the price they are surprisingly good value.
      -David VanHorn
        • 31198
        that's the same basic hardware as the one i linked for under $10
        i got one expecting to have to change the buffer chip only to find the chinese had already updated the board!
        • Spork Schivago
          • Mar 2012
          • 4734
          Are you using the latest version of Sigrok from their github repository? How stable is it? I've been planning on using the libserialport library that Sigrok uses and develops (I believe) to control my Weller WHP3000 preheater. I wanted to release the code open-source on github for other people but I didn't want to have to write separate code for Windows and for Linux. libserialport seems extremely portable and does all the hard work for me.
          • Spork Schivago
            • Mar 2012
            • 4734
            I think I'm going to be happy with my 16702B when it comes. I was thinking of replacing the 18GB SCSI2 drive with one of those SCSI2SD adapters. They plug into a 50-pin SCSI port and can emulate SCSI 1 or 2 from what I've read and you just use a MicroSD card. They support SDSC, SDHC, and SDXC. The price is a little steep compared to something like a 146GB SCSI Ultra 320 drive but I'd still need an adapter for that to work in this. If the hard drive is bad, I'll probably by the SCSI2SD adapter. If it's good, I'll probably wait a few months before making the upgrade.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              #26
              At the time, I used the latest one downloaded from the latest ubuntu repos (which was for a higher version than 12.04 I am running on the machine I use for electronics stuff). At that time it was the same version as the one on their official download page IIRC. I don't know if it would be latest version now. I haven't needed to use it for a while.
              Mostly it worked fine, but sometimes it would stop capturing prematurely. This happened in pulseview and sigrok. I suspect the hardware. I think I found a post about it online saying the same thing. I can try to find it again if you want to know the exact problem.
              But aside from that issue, everything seemed OK for what I did. I never used protocol decoding so far because I so far have not needed to. But from the demo capture files included it does seem to work.
              Good thing about it being open source, I expect it would be quite easy to implement new decoders.
              -David VanHorn
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                It's okay about the exact problem, you don't have to look for it. I know they're actively developing it. I had to ask a few questions about the source code and signed up to the mailing list. I just never unsubscribed. It's almost every day now I get a few e-mails with changes to the code. I was under the impression that maybe using the latest from the repository would be a better idea than the version on their site simply because of how knew the code is. I believe there were a lot of changes made upstream (on the github page) that would fix a lot of problems. Thanks for the feedback! Much appreciated!
                • japlytic
                  • Oct 2005
                  • 2086
                  In case you didn't know, there are SCSI2CF (SCSI to CompactFlash) adaptors on the market as well.
                    • 31198
                    very expensive last time i looked at scsi2ata adapters, i would just fit a 36gig scsi drive in it.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      You should have plenty fun working with that. People may not see you for days.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #31
                        The SCSI2SD adapter isn't that bad. With shipping, around 69$ http://www.ebay.com/itm/SCSI2SD-3-5-...AAAOSwFnFWBHDt
                        I couldn't find one that didn't come with the MicroSD card. I'd probably just use one of ours. We have up to 64GB. That should be more than enough, but maybe I'll just take it up to 128GB. I worry that the MicroSD card might ware out a lot quicker than a SCSI2 drive would...
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #32
                          Yeah So, I've been trying to get this dang oscilloscope module I bought broken, fixed, to use with my logic analyzer. I contacted China and they found a bunch of the ICs I were looking for. People over on EEVBlog say it's some sort of Logic Array / Gate Array / ASIC and they're programmed during manufacturing and there's no way to program them in the field. So we're hoping the ones China sent me are programmed properly, you know, for this oscilloscope module.
                          I guess they're kind of like PICs were the pinouts can change. But only when they're making them or something.
                          Here's a problem I got though. On the back, there's two missing SMD caps. They're 10nF SMD ones that blew off / exploded I think. The IC that I was talking about, it had a screw on the pins and I think that shorted stuff out and made those caps explode. I don't know what voltage SMD caps I should get though. I don't know what type of SMD caps I should get either. I was thinking if they exploded from being shorted out, maybe they're those MLCC SMD caps? I was also thinking maybe I could just order some 15V 10nF MLCC SMD caps and see what happens. From the datasheet, I didn't see any voltages over 5V. The datasheet was just giving a very brief overview of what the chips do though.
                          Any suggestions?
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            So what was the 10 nF connected to a crystal? I would imagine the type of cap would be determined where it was used. The only reason you can not program a gate array in the field would be because they do not want you to know how it is program. The gate array as I remember is full of NAND logic they can be programmed burnt in the field to configure almost any Boolean logic circuit.
                              • 31198
                              crystals use caps in the pF range
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Sorry Stj I will make that 10 nF into 10,000 pF
                                  • 31198
                                  very funny.
                                  then i will also rephrase.
                                  crystals use caps in the 5-30pF range
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Thought you might like that one. Thanks for the info. I could not remember the values. From old school we made oscillators out of discrete components back in the 70's. First crystal I came in contact with was around 1982.
                                      • 31198
                                      yea, 7404, crystal, 2 caps, maybe a resistor.
                                      classic clock circuit.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #39
                                        Thanks for the response Keeney123. So, do you think just replacing this IC won't be enough? It'll need to be programmed? Or do you think there's a good chance that it's actually programmed? Someone, I think STJ, said they thought the part number was more or less an internal part number used by Agilent / HP. To me, that means if I find the same chip with the same part number, there's a good chance it's been programmed the same way or it's simply not programmed at all.
                                        As for what it's actually connected to, I'm not sure, besides the gate array. The Logic / Gate Array had a broken screw grounding out terminals. I can't find schematics for the oscilloscope module. Physically looking at it, it looks like both of the caps just connect to different pins on the IC, through vias. I can't see many traces. I think maybe there's more than just two layers. I could use a DMM and try figuring out where the vias go to if it'd make a difference, like what pin number, etc.
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          I was just saying that a gate array can be programmed in the field. If HP was responsible for making this machine you might what to call them to make sure the IC is programmed. Also, if this O-scope is an older model you might also be able to get the schematics from them. The schematic would be useful if there has been more taken out then one chip. I fact the chip may not be damage, you might of taken out a power supply circuit. It would depend on actually what was shorted and how it is connected in the circuit. The schematic would also be useful if you need to repair this thing in the future. If they are unwilling to give you the schematics there must be some company that either sells them of you can get for nothing.
                                          • jiraiyaishere
                                            Recover data from Lenovo Thinkpad X1 Carbon 6th Generation w/ USB Logic Analyzer
                                            by jiraiyaishere
                                            Hi there, apologies I'm a real noob with this sort of stuff so please bear with me:
                                            A week or two ago my laptop randomly started having the Blue Screen of Death and bootloop every time it booted up. So I tried the recovery options while trying to retain the data: the laptop then said you need a Bitlocker Recovery Key. I never selected for the drive to be bitlocker encrypted so this was really weird to me- I have looked through every Microsoft account I own and none of them have the bitlocker recovery key.
                                            After researching I came across this article: https://dolo...
                                            08-13-2022, 07:53 AM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • korben_dallas
                                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                            by korben_dallas
                                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                            MY QUESTION:
                                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                            02-14-2024, 12:23 AM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • mferna14
                                            Logic Board 820-00840-A Missing EDP_BKLT_EN
                                            by mferna14
                                            Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                                            07-10-2024, 05:18 PM
