2in1 rework station
    • 31024
    Re: 2in1 rework station
    the xytronics irons are far superior,
    the irons on all the cheap bases look the same because they are all clones of a Hakko 900-series
    • Stefan Payne
      • 1267
      Well, I'm thinking about replacing the 307 standard iron on my LF-8800 with the 210ESD one.
      Mainly because the standard one has so tiny tips with a small contact area.
      The 210ESD looks a bit better...
        • 31024
        make sure they are compatable, not all xytronics irons use the same type of sensor.
        • Stefan Payne
          • 1267
          Oh man, why are they doing that?
          Why don't they use one kind of system for all their units so that the irons would be interchangable?!
          Anyway:
          What do you think of those tips?
          http://www.xytronic-usa.com/shop/category.aspx?catid=20
          Forgot to buy the "right" replacement tips when I bought the station...
            • 31024
            interesting, they look similar to weller tips.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I ended up getting a 2-in-1 SMT rework + iron for the heck of it. Was able to remove SMT parts, though it took a while to melt the solder (never used one before, perhaps this is what to expect... The heat gun was faster but tends to blow parts away.)
              The pencil solder iron that was the other half feels cheap. It has a slide on cover that holds the tip to the heating element. I think it still took a good minute or so to hit 200C.
              I'll need to do a heat speed/regulation comparison of my old Ungar and this MiC thing...
              I also still don't understand that black plastic handle thing with the two wires screwed onto it that comes with these rework stations, WTF is this for, and how do you use it? "IC extractor tool" ?
              Last edited by eccerr0r; 12-09-2015, 02:28 PM. Reason: New question while we're at it!
                • 31024
                it's for lifting square packages by the corners without burning your fingers.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  That's what they claim but the wires are very "springy" and once the solder lets go, head I lose, tails gravity and hot solder splattering everywhere wins.
                  Maybe I'm not using it right...
                  • clearchris
                    • Dec 2013
                    • 687
                    Light pressure on the extractor tool. Its meant to prevent you from tearing traces by reducing the pressure on the chip. Once the solder melts, the spring wire pops it off.
                    If you are having chips go airborne, loosen up your deathgrip. Light touch is all thats needed.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Thanks, that advice helps. After years of working with through hole, trace treading is a well known problem. I was trying to use tweezers but it definitely comes with a potential for ripping traces off the board.
                      I guess this tool does have some explanation after all, unlike the three seashells... I just wished it wasn't called an "extractor" (I have DIP and PLCC extraction tools, whose use is very different from this) and more of a "nudger"...
                      Now that's also an awful name for a tool...
                      • Stefan Payne
                        • 1267
                        They don't just look similar.
                        They are.
                        I ordered a Weller tip to try it and it works/fits to my Iron
                        So thanks for the tip
                        • shahnld
                          wds-580 rework station issue
                          by shahnld
                          Good day.
                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                          kind regards...
                          03-28-2024, 01:14 PM
                        • minimania
                          Need Schematic for jbc am6800 rework station
                          by minimania
                          hi all im looking for a Schematic for jbc am6800 rework station
                          mine has stopped working fully
                          it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                          now it wont turn on at all...
                          01-28-2025, 03:44 PM
                          DELL Latitude 9520 2in1 Hybrid (2-in-1) 9000 Specification for Upgrade or Repair
                          This specification for the DELL Latitude 9520 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9520 2in1 boardview and 9520 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-07-2024, 12:40 AM
