CH341a SPI / I²C programmer
  • Marcustv
    replied
    Re: CH341a SPI / I²C programmer
    What is the latest free working version that can be found in the programmer's software
    replied
    ch341 virtual comport drivers are at WinChipHead
    http://www.wch.cn/products/CH341.html
    downloads at the bottom
  • SoporteHR
    replied
    Hi. Spork Schivago
    Use Windows 10. Now download the driver and software that corresponds to that programmer. I have already successfully recorded several CHIP BIOS.
    But I wanted to evaluate serial connections to connect to ADSL modems.
    Thank you.
  • Spork Schivago
    replied
    If you're in Windows, you'll more than likely need drivers for that programmer and in Linux, you'd need the proper module(s) before you can start using it. If you tell me the OS, I can help find drivers so the software you run to program the chips can properly communicate with that programming device...
  • SoporteHR
    replied
    Thank you
    I'll do the tests, then I'll tell you.
    Greetings.
    replied
    on Linux it will be ttyUSB0, on windows you may need to configure the serial driver - but i will show as a com port
  • SoporteHR
    replied
    Do I require any special program for that function or with any program such as telnet or putty?
    Thank you
    replied
    yes, the programmer can act as a 5v or 3.3v serial port to talk to other stuff like routers or ST microcontrollers etc.
    the jumper across pins 1&2 configure it as a programmer - move it to pins 2&3 to act as a serial interface.
  • SoporteHR
    replied
    Hi, STJ.
    I explain myself better
    When I referred to the (BIOS Connector), I wanted to tell the connector zero insertion force, highlighted in blue in the photo that I attached.
    On the connectors that are next, I would like to know if they can be used to program modem or communicate via serial with other devices.
    Since in red, I see a serial connection I assume RS232 to TLL.
    and highlighted in yellow, I see MOSI / MISO connections. which corresponds to the one obtained in the router / Modem ADSL cards for example.
    I wanted to know if you can program or communicate with these devices using this programmer as an interface.
    replied
    bios connector??
    ch341 is not jtag, it's spi/i2c
    bios?? connector is either spi or lpc
  • SoporteHR
    replied
    Hi all.
    I have the black edition of the programmer, I would like to know if they have used it as a JTAG interface. To program for example Modem ADSL, WIFI Router.
    If so, as they have done with that software they can make use of the pins that are next to the BIOS connector.
    Thank you.
  • yaoyao24
    replied
    Originally posted by stj
    macbooks from 2012 wont be the same as 2017
    i prefer to lift chips for flashing - it eliminates any chance of error.
    thanks so much. i'll try
    replied
  • yaoyao24
    replied
    well you need to check the schematic, there may be something else linked to the connector.
    i tried with old main board, macbook pro 2012 it stilled working. i dont think it have problem with the connector
    Originally posted by megaraider
    imho it's bit odd when someone tries to erase the bios hopping to clear the password...
    i read the bios - edit - erase and reflash again
  • megaraider
    replied
    Originally posted by yaoyao24
    clear bios password for macbook pro 2017
    replied
  • yaoyao24
    replied
    did you remove the chip first?
    and did you save a backup?
    i didn't remove the chip, i had tool just plug in the connector. i had backup file
    replied
  • yaoyao24
    replied
    Hello. i used CH341A Mini Programmer to clear bios password for macbook pro 2017. it detectd the chip, read ok but when i tried to blank, it said 'the chip are not null' and now it broke the bios chip, laptop not turn on. Can u help me to fix the problem ? thanks so much
  • killdan
    replied
    Originally posted by osmanlee
    New version of ch341A 1.34
    Thank you very much. It's saved me much time.
