Hakko 936 soldering iron - tips don't fit
  • redwire
    • 3912
    I took apart a Hakko 907 wand on a 936 soldering station.
    Tip 900M-T-1 (on the left) is too small to fit on the heating element.
    Tip HAKKO-B (on the right) is too big and loose to fit over the heating element.
    I dunno what is messed up
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Hakko 936 soldering iron - tips don't fit
    It looks like that the sleeve has slid out of the tip and has stayed on the heater.
      • 31197
      probably.
      the heater should be white ceramic, not metal-looking.
      • MEB
        • Sep 2013
        • 371
        Sorry the ceramic was white one day, but I think the above comments are exactly correct. If you look into the opening of a tip, you can see the inner sleeve or the lack of.
        • redwire
          • 3912
          I looked harder and it's an insert pipe stuck to the heating element. Gentle tug and it's off. The heater now fits into a normal 900M tip (4mm ID). Insert was 4.3mm OD.
          I don't know what Hakko tip has inserts, must be pretty old. I took the iron out of the garbage from Manufacturing dept.
          I could buy a new 907 wand (chinese) clone for $8 on eBay, but they are a lot of hassle. The heating elements are the wrong resistance, temp sensor different and can wreck your 936 station.
          http://www.eevblog.com/forum/reviews...-heater-a1321/
            • 31197
            if you need a new iron, either get a chinese hakko T12/T15 clone, or a real JBC.
