Your main multimeter: accuracy?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8697
    Just a dumb poll on the accuracy of your "main" multimeter that you use most often.
    I noticed my Fluke was "3200" count, if yours is similar vote the next higher one (in this case, 3999 or 3 3/4)
    10
    Analog without mirrored scale
    0%
    0
    Analog with mirrored scale
    0%
    0
    3 digits or less (1000 count) Integrating
    0%
    0
    3 1/2 or 1999 count Integrating
    0%
    2
    3 3/4 or 3999 count Integrating
    0%
    1
    4 or 9999 count Integrating
    0%
    1
    4 1/2 or 19999 count Integrating
    0%
    4
    5 or 99999 count Integrating
    0%
    1
    6 or more digits Integrating
    0%
    1
    SAR (you're using a 'scope) or none of the above (describe below)
    0%
    0
    The poll is expired.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Your main multimeter: accuracy?
    You obviously mean the word "resolution", not accuracy.
    Accuracy is something like 0.5%.
    --- begin sig file ---
    --- end sig file ---
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • Asraf Atb
      by Asraf Atb
      01-27-2025, 05:02 PM
    • JSin21
      Compatibility of main boards between different variations of samsung MU6100
      by JSin21
      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
      I have Samsung Smart TV UA65MU6100WXXY version DA01
      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
      11-27-2023, 04:54 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
