Your main multimeter: accuracy?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Just a dumb poll on the accuracy of your "main" multimeter that you use most often.
    I noticed my Fluke was "3200" count, if yours is similar vote the next higher one (in this case, 3999 or 3 3/4)
    10
    Analog without mirrored scale
    0%
    0
    Analog with mirrored scale
    0%
    0
    3 digits or less (1000 count) Integrating
    0%
    0
    3 1/2 or 1999 count Integrating
    0%
    2
    3 3/4 or 3999 count Integrating
    0%
    1
    4 or 9999 count Integrating
    0%
    1
    4 1/2 or 19999 count Integrating
    0%
    4
    5 or 99999 count Integrating
    0%
    1
    6 or more digits Integrating
    0%
    1
    SAR (you're using a 'scope) or none of the above (describe below)
    0%
    0
    The poll is expired.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Your main multimeter: accuracy?
    You obviously mean the word "resolution", not accuracy.
    Accuracy is something like 0.5%.
    --- begin sig file ---
    --- end sig file ---
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • semiRocket
      Toshiba 37bv701b power supply main rails
      by semiRocket
      The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
      I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
      Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
      10-26-2025, 01:55 AM
