Fluke 101 and response time (continuity / voltage)
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Hey all,
    From a discussion in the TV forum, I am considering and idea by retiredcaps of purchasing a fluke 101 for my tv testing. I am still a complete amateur at this, and my budget is very limited.
    Even with my limited budget, I do want to get a meter that can do what I will mostly need for TV troubleshooting. In that , the need for quick and reliable audible continuity check, and quick and reliable DC voltage testing, seem to be important.
    I've read that all fluke meters boast a "latching" continuity check circuit that works quite well and is fast. Would this be true for the Fluke 101? Also, how would the other DC measurements compare to the higher priced Fluke and BK meters?
    Thanks!
  • titomno2
    Gaming Laptop Zephyrus S17 TFT not detected every time !
    by titomno2
    Hi guys,
    I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
    So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
    On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
    Then the screen won't work for a long period of time.
    If I wait 1 or 2 hours it work again most of the time.
    When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
    01-19-2025, 08:27 AM
  • flat-earther
    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
    by flat-earther
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in...
    06-08-2025, 02:00 AM
  • EasyGoing1
    UPNP, "Standards" and hardware that implements it
    by EasyGoing1
    I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
    One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
    So I decided to implement UPNP...
    07-16-2022, 07:12 PM
  • OscarAV
    HP Pavilion dm4-1065dx long time to get the power led on
    by OscarAV
    I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
    I have made a quick search for my laptop but I have not seen anything similar.
    I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
    09-23-2024, 05:53 PM
  • Dodgethis
    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
    by Dodgethis
    Hello all,
    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
    09-11-2024, 07:39 AM
