Honton HT R392 Profile help needed
  • nearxos
    • Jun 2014
    • 41
    • Cyprus
    Hello. i recently bought a Honton HT R392 bga station. and i am trying to figure out how to setup the profiles.
    what i want to ask is does the default profile that is setup on the device a good start to work around and tune it accordingly.?
    Does anybody have any suggestion or tips concerning the R392?
    • 30963
    Re: Honton HT R392 Profile help needed
    a profile is based on the type of solder and make of flux used.
    it's not a one-size-fits-all thing.
    • nearxos
      • Jun 2014
      • 41
      • Cyprus
      Yea i know that.
      So a laptop motherboard for example is it a lead free solder or a lead based.?
      Flux i got is Amtec and Insat RMA Liquid Super Flux
      Whats the basic steps for creating a profile.
        • 30963
        laptop will be lead-free if it's newer than 2006.
        probably lead-free even if it's older, but 2006 is when the law came into play.
        Amtec flux, 9 out of 10 times is fake.
        Insat flux is unknown - that guy never gives the safety datasheet that he is legally obliged to have.
        it's the so-called "israeli flux" i suppose.
        you can probably get some info on this on the console-repair forums.
        most of insat's customers are doing ps3 repairs.
        one other thing, the insat flux has a lot of rosin and other nasty shit in it - make sure you have a fume extractor over your rig if you dont want health problems later.
        • nearxos
          • Jun 2014
          • 41
          • Cyprus
          i know about amtec. not sure about the one ihave now i got it with the machine.
          i order one from bgamods.co.uk which suppose to be the real one.
          and also ordered kingbo flux still waiting for it also.
          • xboxhaxorz
            • Jan 2011
            • 196
            please follow this http://www.thebgareworkmachine.com/r...e-development/
            • nearxos
              • Jun 2014
              • 41
              • Cyprus
              Originally posted by xboxhaxorz
              thanks for the link.
              which flux do you consider a good choice and for what purposes
              • xboxhaxorz
                • Jan 2011
                • 196
                kingbo flux for everything
                • nearxos
                  • Jun 2014
                  • 41
                  • Cyprus
                  Any good website you know off for kingbo flux?
                  • xboxhaxorz
                    • Jan 2011
                    • 196
                    kingboflux.com
                    • chth96
                      Is it good to use chemistronic flux off es835b for flux remover?
                      by chth96
                      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                      11-17-2023, 07:25 AM
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • evilkitty
                      Flux causing high resistance short?
                      by evilkitty
                      Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                      Temp is on the left humidity is on the right
                      i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                      The pin out looking down from the top is (note this is common cathode)...
                      07-17-2024, 09:38 AM
                    • chth96
                      How can I remove flux with the smallest rubbing?
                      by chth96
                      I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                      Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                      Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                      Is there any way to remove flux with the smallest rubbing or without any rubbing?
                      Any reply would be appreciated.
                      11-24-2023, 05:22 PM
