800F Not hot enough..
  • ChaosBlizzard
    • May 2004
    • 32
    Well I just replaced some caps on my vp6.. I came into 2 holes that wouldn't melt and give. I had to press the damn soldering tip from my hakko FP-102 for a while until it would melt, even with fresh solder.. I have no idea what kind of solder abit is using but its not light. I finally got them cleared and new caps in.. But the back of the board is somewhat "burned" from the excessive heat. To top it off, the two panasonic caps between the AGP and PCI are too big. I am hoping tomcat will sell me those two. I couldn't plug my video card in, but the system did turn on without blowing up . It posted two beeps.. Which is prob from the video card not being in. It took me a while to learn and start heating both leads up on a cap instead of one.. Man did things speed up after that.. I also came into less clogged holes that way. Hope my board is ok, the pcb just looks brownish around those two annoying holes..
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Just install the caps between the AGP and PCI1 sideways. I do that on all of them. Stops the caps from interfering with AGP cards. Locating low-profile caps to fit that is impossible with a quality brand.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ChaosBlizzard
      • May 2004
      • 32
      Well I already clipped the stupid things when I put them in.. Well the one I did anyway. I didn't get the other in the mail.. But when I do I will follow your advice. Now that leaves me with that one cap that needs to be replaced due to size and being clipped..
      Thanks,
      Cody
      • gg1978
        • Dec 2004
        • 431
        There's probably a substancial ground plane in there, which sinks the heat away from the iron. It's certainly an acquired skill, working on mainboards and replacing caps..
        • defdjamel
          Solder won’t melt on MacBook 2021 logic board – need advice
          by defdjamel
          I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
          https://www.electronicsdatasheets.co...s/tlv70733pdqn
          I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
          I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
          Do you have any tips for this kind of board? Would a preheater help?
          Thanks in advance!
          09-05-2025, 08:56 PM
        • Hornnumb2
          Soldering help.
          by Hornnumb2
          I am at my wits end trying to get these 2 hole clear. The other 2 holes no problem. I tried low melt, hot air, wick and my solder sucker gun. One hole still has the pin in it. I have my iron up to 450 with a big tip, hot air turned up to 500. Any suggestion? Thanks Michael
          And by the way it took me 10 minutes to find the login button, it sure needs to be a brighter color or something.
          04-07-2024, 06:52 PM
        • Nier
          Drilling out solder from capacitor holes
          by Nier
          I have an xbox 360 board that had 4 leaked electrolytic capacitors. I desoldered all 8-10 capacitors (1500uf 16v) since 4 leaked and wanted to replace all of them. 2 capacitor legs broke and were stuck in the through hole.
          My two solder suckers just didn't work and I decided to use my dremel lite in the lowest speed to drill out the broken capacitor legs. I used a carbon drill with the exact diameter size as the capacitor hole. I drilled out the capacitor legs but I think that I damaged the holes. I don't think that the solder will adhere through the hole if If I solder a new capacitor....
          10-05-2021, 09:48 PM
        • televizora
          Drilling holes laptop bottom
          by televizora
          I wonder if drilling a few holes in the laptop case, on the bottom below the fan will actually help and decrease the CPU/GPU temps. I have one spare not so new laptop with first gen core i5, but the main issue is that while the cooling systen is clean, it runs rather hot - youtube tends to bring the laptop to about 60-64 degrees, even if power plan with 60% power limit restriction is used and the cpu itself does not go above 1.2-1.4GHz. It has integrated graphics, this is true, but the temps seem a little bit high... Even the SSD runs above 55-60 degrees, while it isnt actually intensively used......
          08-04-2021, 09:49 AM
        • DXseekerMO
          Post your Samsung NU model series backlight failures and diffuser melt-downs here!
          by DXseekerMO
          So I started this thread for all of us TV fixers to post our Samsung NU model series backlight failure and resulting main diffuser melt-downs. Please do post pictures!
          Either Samsung needs to recall these TVs for this problem or provide owners with updated parts that will not repeat the same failure!
          I will start:
          Samsung UN40NU7100FXZA, left-side backlights failed, left side of main diffuser and reflector sheet behind it melted in the shape of the LEDs below it. Picture #1 and 2 below.
          Samsung UN65NU7100FXZA, left-side backlights failed,...
          06-11-2021, 02:20 PM
