Concerns before attempting a Reflow of Laptop's GPU
  • Mr_Nada
    • Jun 2024
    • 4
    • Unitied States
    I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
    I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
    I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
    • The paper that came with the thermometer states that the probe is rated for over 300C (K type,Tp-01), I've already tested it in ice water and it appears to be accurate.
    • The tape is rated for 500F or 260C (I'll come back later and edit it when I find the brand name again)
    I'm concerned if:
    • The thermometer that I have will be accurate enough for this
    • The board may warp from only heating one side
    • The flux I have may cause some unforeseen problems with the reflow.
    • The Airgun will for some reason not be powerful enough (if it turns out that I need more heat than it's able to output)
    I'm unsure about:
    • How long I have to let it heat up for
    • What temperature I have to set/let it heat up to
    Is there anything I should consider switching out or is there some guide that I missed that would help me figure out some what I'm unsure about?
    If it works I plan on adding some stuff to the GPU so it won't heat up as much and break its solder balls.
  • Olvin1
    Acer nitro 5 an517-52 reflow/rebal CPU
    by Olvin1
    I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
    I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
    • A detailed temperature profile for reflowing this specific CPU
    • Step-by-step guidance for a safe and effective reflow process
    • Tips on what to watch out for during the procedure
    If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
    08-01-2025, 01:59 PM
  • Simplebeans
    MacBook Pro A2338 keeps restarting when attempting to install macOS
    by Simplebeans
    I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
    After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
    08-10-2025, 11:04 AM
  • groomit
    Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
    by groomit
    I just replaced the battery on a Google Pixel 5.
    After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
    Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
    The rubber seal is on again (as mentioned in various suggestions in other forums).
    This smells like a cold or broken solder joint. So I'd like to reflow...
    06-11-2025, 02:21 AM
  • Davi.p
    For BGA reflow experts...
    by Davi.p
    I have attempted all sumed very few reflow processes, and i need to make it better, how do you make yours to have sureness that the balls are really fully reflowed? My temptation was always to do "the slight move" touching very gently an angle, but due to some cases, but maybe 100%, where the previously half working device became totally shut off, i finally understood that the damn "move" makes the balls shorted, so what do you suggest?
    Thanks!.. Muchas gracias.....
    11-23-2024, 10:36 PM
  • tony359
    Reflow equipment
    by tony359
    Hello all,
    I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
    I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
    Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
    12-25-2021, 01:29 PM
