Just got my 50MHz differential probe, I need suggestions for extra test leads
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Possibly one of my happier moments as professional repair man, is by getting this differential probe PINTEK DP-50 even as used, which is capable to handle RMS voltage of Mains (x100), and up to three phase system (x200).
    Plus for electronics up to 1.1KV RMS (x500) & 2.3KV RMS at (x1000).
    For electrical measurements I am good to go with test leads that I own all ready, as for example professional HV large alligator clips.
    What I am expecting as suggestions is any recommendation of specialized HV test probes, which helps more in measurements in electronics.
    In the positive side of things, I would say that my GW Instek GDS-2102A oscilloscope inputs, are now safe.
    Probes Isolation issue is solved for good.
  • fpliuzzi
    • Nov 2012
    • 15
    Re: Just got my 50MHz differential probe, I need suggestions for extra test leads
    I came across two accessories made by PINTEK that may be useful to you for your newly acquired DP-50. See what you think of them...
    PINTEK BP-266: HV IC Clips. These are rated to 6500V (DC + AC p-p)
    PINTEK BP-366: HV banana to banana plug cables (UL20KV)
    The LeCroy AP031 HV differential probe that I own can handle 1400V maximum, so my HV test cabling requirements are less stringent than yours. The test leads/probes that came with my AP031 work quite well and securely clip onto component leads or wires (for hands-free HV measurements).
    • Kiriakos GR
      Banned
      • May 2012
      • 940
      • Greece
      Hi Mate,
      After gettiing the probe with out HV cables and HV test leads, I did discovered how dificult is to replace them.
      By reading the user manual I did discovered the actual spesifications of those accesories.
      I did manage to get parts for making my own copy of PINTEK BP-366: HV banana to banana plug cables (UL 20KV)
      But nothing comes close to PINTEK BP-266: HV IC Clips ( 6500V DC + AC p-p)
      Instead loosing my smile, I did get insted 1000V RMS probes which are suficient for general use.
      Currently I am trying to find a supllier for those BP-266 but is not easy.
      The lesson for this story is that if your apllications are exlusivly HV and higher than 1KV RMS, the probe and these special HV test leads they should always come together.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        If you have not visit this link yet, you better save the pictures as reference about it internal parts. http://bardagjy.com/?p=1664
        • fpliuzzi
          • Nov 2012
          • 15
          Thanks for the link
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            My 20KV silicone wire just arrived, I got three meters (10ft) and I feel lucky all ready about making my own custom length of wires .
            • perfm2
              Wson8 spring pin probe WORKS
              by perfm2
              I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
              I recently ordered one to give it a shot and it actually worked quite well.
              The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
              I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
              This aided greatly in allowing the probe to stay in place...
              03-30-2023, 11:19 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • AlexForTheWin
              Help Diagnosing ASRock Taichi X570 Motherboard
              by AlexForTheWin
              Hi all! I'm a newbie to to the forum and electronics repair in general.
              I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
              I'd very much appreciate some guidance.
              Here are the steps I've taken to diagnose the board:
              I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
              Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
              12-16-2022, 11:37 PM
            • digitalDNA
              MOSFET maintains voltage drop across G and S only for 3 seconds
              by digitalDNA
              While trying to fix an SMPS, I hear a ticking sound.
              I've checked all capacitors, but none seem to be shorted.
              I then suspected an issue with the flyback transformer which has 3 leads on the primary (used in a push-pull configuration ?) and one of them, which is always connected to GND has a resistance reading in the order of Mega ohms with any of the other 2 leads on the primary.
              But I thought let's check the MOSFETs first::
              The circuit also contains a PFC circuit, controlled by a UCC3818D (D stands for the SMD version),...
              10-11-2022, 11:00 AM
              ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
              Optimized Multi-Phase PWM Controller
              with 6-Bit DAC for VR10.X Application
              The ISL6556A controls microprocessor core voltage
              regulation by driving up to 4 synchronous-rectified buck
              channels in parallel. Multi-phase buck converter architecture
              uses interleaved timing to multiply channel ripple frequency
              and reduce input and output ripple currents. Lower ripple
              results in fewer components, lower component cost, reduced
              power dissipation, and smaller implementation...
              11-05-2024, 03:10 PM
