Program XGECU T56
  • Domenicoo
    • Jan 2024
    • 11
    • Italia
    Program XGECU T56
    Good evening guys, having a corrupt bios file I had to download several new bios files, but when I go to load them on the XGECU T56 programmer all the folders are empty where is the error because what am I doing wrong. Please can you help me understand, thank you very much..
  • peste
    • 13600
    • ROMANIA
    ​Where did you get the files? How did you load them into the programmer? Give more details..
    Last edited by Vesko356; 01-25-2024, 04:35 AM. Reason: Post moved from Bios requests sub-section
    • Domenicoo
      • Jan 2024
      • 11
      • Italia
      Hi, I downloaded the files from here Bedcaps.net Bios section for laptops. They arrive in a folder (Unzip), I bring them back to the desktop and with the XGECU t56 programmer I go to load them but when I open the folder it doesn't find any files. I'm definitely wrong in some passages.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12330
        Định dạng của lập trình viên là *.BIN , tệp bạn tải có định dạng thế nào ? . The programmer's format is *.BIN, what format is the file you downloaded?​
        • Domenicoo
          • Jan 2024
          • 11
          • Italia
          this is how they were downloaded
            • 31250
            that second icon is strange - did somebody rename a zip file to .bin???
            • Domenicoo
              • Jan 2024
              • 11
              • Italia
              I don't know if someone has renamed the file, the fact is that when I open the XGECU T56 programmer and go into the folder it appears empty. I can't understand and I'm asking you if you can help me understand something. Thanks to everyone who attended.
                • 31250
                what is the file size?
                  • 31250
                  T56 software update online
                  http://forums.xgecu.com/viewthread.php?tid=20
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    The BIOS file you download is in *.zip format.
                    Thus, 'onedrive' and W10 will let you see the contents without extracting them (in fact they're extracted, but to a temp system folder).
                    Tips to answer you question:
                    1. download the *.zip to your hard drive (do not use 'onedrive')
                    2. once downloaded go to the folder where you downloaded it, select the file, then right mouse click and select 'extract'
                    3. only then the bios_dump.bin file will be visible in the programmer software
                      • 31250
                      and set windows explorer to show ALL file extensions.
