Picking the right pcb preheater within budget.
  • beggi90
    • 16
    • Iceland
    Hi, I've wanted to try reballing for some time.
    The only equipment I need at the moment is the bottom heater and something to measure the heat on the board.
    I went on ebay but wasn't quite sure what I should look for in the specs.
    Should I get one that monitors the heat on the board also or should I buy a different "unit" to monitor the heat.
    How big heating area should I look for?
    Budget is about 2-300$.
    I was looking at High Power Infrared PCB IR PREHEATING OVEN.
    But then I found Aoye 853A which looks much better but has to small heating space (I think).
    Not really thinking of buying this as professional equipment, just to repair things I couldn't for bragging rights
  • beggi90
    • 16
    • Iceland
    Re: Picking the right pcb preheater within budget.
    Is my budget to low for a bottom heater?
    • MDOC
      EngineeringTech
      • Mar 2010
      • 146
      Well, you said 2-300, so it can be interpreted as "from $2 to $300"
      I think you meant 200-300.
      (Sorry, can't recommend one for you, I never did reballing.)
      • deep000
        Looking for a budget hot air soldering station for hobby use
        by deep000
        I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
        Any recommendations for a "good" cheap one that gets the job done?
        Thanks in advance
        04-25-2025, 02:29 AM
      • caphair
        Anyway to increase the temperature of this preheater?
        by caphair
        It's a preheater for iPhone models X-11 that use low melt 138c solder between the sandwiched layers. Has a constant temp setting of 180-190c
        I want to use it for newer iPhone 12 models which use a higher solder between the layers I believe 168c.
        Anyway to increase the temp of the preheater to 230c?...
        04-19-2022, 02:45 PM
      • ducky29
        Working with Bga chips especially CPUS
        by ducky29
        Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
        Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
        Thanks in advance.
        09-23-2024, 03:56 PM
      • slybunda
        Picking long life capacitor replacements?
        by slybunda
        to pick some good quality capacitors for long lifetime do i just go to mouser, rs etc and select the capacitance and voltage then sort by the highest number of hours and pick the caps that have the highest number of lifetime hours?
        02-08-2024, 03:56 AM
      • lee8889
        Samsung, LG or TCL Buying Budget TV 2023 (Brazil)?
        by lee8889
        Hi all, im looking to buy a lower end new TV and have limited choice here in the North east of Brazil where im currently living. The main choices are Samsung, LG and TCL, just looking for opinions on reliability, OS etc.? I am currently researching if there are any differences on the components, manufacture etc. here in Brazil compared to Europe, but just some general opinions would be great!
        Looking at 50 inch, something like the Samsung CU7700. Have a Nvidia Shield so operating system im flexible with as long as its smooth and reliable.
        10-18-2023, 08:13 AM
