Soldering Station upgrade, what to look for?
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Soldering Station upgrade, what to look for?
    Originally posted by digge
    Im leaning towards a JBC unit, more specifically the CD-2BC (or CD-1BC for you 110V ppl ).
    Does anyone own one or at least have used one and can tell me anything about how it performs/feels? Also how good are the tips, will they last long?
    Heaven opened up today and your wish it did pass thru the clouds.
    Got that message today.
    • woodscroller
      • Jul 2013
      • 27
      Originally posted by Kiriakos GR
      Please do for me the favor to retype your message in Greek, your lingo is far from basic English that some one could learn is a school.
      1 If English isn't your first language, good for you.
      2 If one insist on perfect grammar and punctuation, they should also practice it... native first language or not.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        3) When you do care to coexist in a forum with international visitors you should try to not use sayings that have some value exclusively for an American reader.
        4) Travel more outside of USA
          07-01-2024, 06:34 AM
        • mkbehbeh
          KSGER C245 Soldering station PSU 220V only?
          by mkbehbeh
          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
          I am...
          04-17-2023, 03:11 PM
        • Peter_1402
          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
          by Peter_1402
          Hi Everyone,
          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
          1. Soldering iron works great
          2. There is a burnt mark on the hot air gun handle.
          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
          Reed switch tested ok with a magnet.
          From the above test, I can conclude...
          07-12-2025, 11:50 AM
        • nbdy
          QUICKO soldering station
          by nbdy
          HI,
          Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
          All worked nice, till some day it heats the iron till it was RED (HOT) ...
          Turned it off, and tryed today again, and all the same, even with a second iron ...
          The display shows that the iron is not connected, like not inserted in the handle ...
          The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
          Has someone some advice what to do, where to look, even how to...
          01-07-2024, 05:44 PM
        • Dreigas
          ISL95880HRTZ desoldering temperature
          by Dreigas
          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
          09-13-2024, 10:59 PM
