Ventilation System
  • johnnydiaz
    • Apr 2012
    • 52
    Ventilation System
    What are you guys using for a ventilation system when you are desoldering and soldering?
  • mariushm
    • May 2011
    • 3799
    Re: Ventilation System
    A small 80mm pc fan at medium speed (about 9v) blowing air sideways on the desk and an open window.
      My lungs...
      Or I open the window and/or use a desk fan.
      • DerStrom8
        Techie
        • Dec 2012
        • 76
        Usually just an open window a few feet from my workbench. It's the best I can do in my basement at the moment. Luckily I don't do extensive soldering, so that one window is sufficient. If I ended up soldering things more frequently, I'd set up a window fan with aluminum dryer ducting to extract the smoke and fumes. It's cheap, but it'll do the trick!
          I made this from Bath room fan and Charcoal filter.
          http://s807.photobucket.com/albums/y...t=DSCF0519.jpg
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            I don't have any ventilation system yet, I just blow away the smoke if it floats towards my face.
            Muh-soggy-knee
            • johnnydiaz
              • Apr 2012
              • 52
              I don't mind spending up to $300 for a fume extractor ventilation system. Can someone recommend one?
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • hans_meier
                HP EliteBook 840 G6 how to dump without desoldering
                by hans_meier
                I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                01-04-2025, 04:11 PM
              • Dreigas
                ISL95880HRTZ desoldering temperature
                by Dreigas
                I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                09-13-2024, 10:59 PM
              • armini
                18VDC PSU completely dead - ZD-915 desoldering station
                by armini
                Hi everyone!
                Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                Due to a lack of time, I set it aside and didn't look at it.
                Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                According to replies in 18VDC PSU has dropped to...
                04-25-2023, 07:49 AM
              • dennis akumu
                hp elite desk 800 g3 twr bios
                by dennis akumu
                i have this elite desk 800 g3 tower with no display,need a clean me file.
                s/n : SGH802SMK4
                PRODUCT ID: 1VR31UC#ARE
                BOARD NO: Andromeda REV A
                Please clean me please....
                07-11-2025, 05:54 AM
