Soldering techniques for flat chip capacitors?
  • ryn404
    • Jun 2012
    • usa
    Does anyone have any soldering techniques for small flat chip capacitors?
    caps similar to these
    http://media.digikey.com/photos/Keme...L,4.3W_sml.jpg
    i am trying to solder them onto tracks but im trying to find any tried and true techniques before doing so...im just using a 60w solder gun with a fine tip
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Soldering techniques for flat chip capacitors?
    http://store.curiousinventor.com/gui..._Soldering/101
    • ryn404
      • Jun 2012
      • usa
      sweeet! THANKS!
      • mariushm
        • May 2011
        • 3799
        EEVblog #186 - Soldering Tutorial Part 3 - Surface Mount
        http://www.youtube.com/watch?v=b9FC9fAlfQE
        • joe4227
          • Aug 2012
          I viewed the video, and that made me more comfortable. However I still have one problem. The Caps I am replacing are top-hat shaped metal cans. I think the lead spacing on the SM Caps is wider.
          Has anyone run into this? I feel like the proverbial "square peg, round hole" syndrome is work!
          England expects that every man shall do his duty!
          • severach
            • Aug 2007
            • 1055
            SMD Electrolytic caps are quite difficult. How to do them depends on quality. When I'm ripping them off boards to be discarded I apply an iron to each lead and push twist the caps off. This destroys the boards and about 30% of the caps too but it's fast. SMD ceramic and tantalum come off the same way but with no board or cap damage.
            High quality removal and installation of SMD electrolytic caps requires heating the board behind the cap with hot air. This and some flux allows a light touch from the two irons to melt the solder outside to inside and the part desolders quickly before the heat can damage the cap. SMD electrolytic should be melted on both sides at once because the long flat unmelted side does not allow the cap to be lifted up when only one side is melted. If you're going to destroy the old cap by using one iron why not just rip it off the board with a pliers and remove the leads one by one the easy way? That's not such a good idea because lands are often small and small lands don't have much glue holding them on. The part itself may be glued to the board. Heat helps soften this glue.
            SMD caps are easy to install with just one iron so long as one land is clear of solder. Preheat the board, melt and drop the fluxed cap into the solder pool. The other side solders as normal.
            Sometimes boards are traced for both SMD and through hole caps. I pick through hole every time.
            sig files are for morons
            • Azurain
              Elitebook 840 G5 Bios Chip Soldering Question
              by Azurain
              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
              04-14-2023, 06:58 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • majster-pl
              Can a BIOS chip survive hot-air soldering but still lose functionality?
              by majster-pl
              I’ve run into an issue after working with a laptop BIOS chip and wanted to get some advice.
              I desoldered the BIOS chip using hot air and then read its contents with a CH341 programmer (only a read, no write or erase was done). The .bin file was not modified at all. After soldering the chip back, the laptop now no longer powers on.
              For clarity:
              No surrounding components were touched during the process.
              All pads were checked with test points and were confirmed OK.
              My question is:...
              09-08-2025, 04:21 AM
              Common SPI bios chip programming Questions and Answers
              by SMDFlea
              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
              A: If you can`t read from it how do you expect to write to it ?.
              Q: Why is my bios chip unreadable ?.
              A: The programmer is faulty or has a worn or broken zif socket.
              The USB cable is frayed,connector pins worn or some other physical damage.
              Not enough amperage or voltage to power the programmer properly.
              Bad...
              09-02-2021, 04:40 PM
