Soldering iron/station
    Right now I am using a radio shack iron (I don't do much) but it seems like I might get into this a little more since it is so fun. I have a couple gift cards to Amazon. Can anyone recommend a soldering iron or station in the $50 range for a part time user like myself? Also, what kind of tip should I be using to solder/de-solder capacitors? Flat tip or pointed?
    Any other advise?
    J_K_M_A_N
    Re: Soldering iron/station
    Make an effort and get this one at $80 :
    https://www.amazon.com/dp/B004M3U0VU...48R0ABNHAPAC0&
    It's a lifetime purchase, you'll easily find tips for it for the next 10-20 years and it's a quality station.
    As for what tips, it doesn't really matter, and it's a question of personal style. Some like the chisel tips, some can work with conical tips just as well. I have no problems desoldering capacitors with a conical tip. I just apply a drop of flux, then some solder on the leads then apply the tip horizontally on both solder points to heat both at the same time and pull out the capacitor.
      Get this:
      http://www.amazon.com/Weller-W60P-60...7011948&sr=1-1
      I inherited one... It is great for recapping. It also has temp control based on the tip you use- the tips have a magnet on the end that uses curie points to control the temp (the number stamped on the end * 100F is the temp the tip uses). Also the tips are rather inexpensive (usually $5 a piece, and they are well made).
      Also get a good stand/sponge for it if you don't already:
      http://www.amazon.com/Elenco-Solderi...7012360&sr=1-1
      I use one of those... the sponge does wear out; to replace them, find a cheap cellulose sponge (not plastic) and use a utility knife to cut it to size. most sponges can be cut into two that fit.
      I used to suggest these irons:
      http://www.xytronic-usa.com/shop/item.aspx?itemid=99
      But amazon doesn't have them and for some boards, 30W isn't quite enough. (but if all you have is $20, it's a good choice )
      I suggest chisel tips. conical tips don't deliver the heat as well . as for size, get a 1.5mm and a 3mm... the smaller of for precision work (it comes in handy) and the bigger is for recapping and the like.
      sigpic
      (Insert witty quote here)
        I ordered it up. Hopefully I will have it by the end of the week. Thanks for the advice.
        J_K_M_A_N
          Thank you for the suggestion. This thing is a million times better than what I was using. I love it. Glad I spent the money. It heats up incredibly fast and it gets much hotter which makes de-soldering so much easier. I am working on repairing my 3rd and 4th monitor now. Thanks again.
          J_K_M_A_N
