HV Probe Suggestions
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: HV Probe Suggestions
    Originally posted by tom66
    A battery has two types of internal resistance:
    - Electrical resistance, the effects of which occur immediately
    - Ionic resistance, which takes some amount of time to occur (typically several seconds after a load is applied)
    If you dead short a battery with wrench the voltage will be zero LONG before 'several seconds' and the Ionic resistance won't make a lick of difference because there won't be any possibility [potential] for current to flow.
    - All the rest of your discussion happens -after- that. (Even if it's only several seconds after.)
    The battery was being used as a readily available simulator for a high energy cap.
    What happens 'after that' doesn't happen (significantly) in caps and is completely irrelevant to the simulation.
    ~ I didn't want to sprout a side topic that was irrelevant with someone that's already confused.
    ~ That's why I said to ignore it.
    So thanks for bringing it up anyway....
    And no.
    If you put a spanner across battery terminals it won't be full volts across the spanner.
    Not sure where that even came from.
    Volts will be near zero faster than the response time of most meters.
    Mann-Made Global Warming.
    - Dr Seuss
    • howardc64
      Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
      by howardc64
      Samsung have been using this style LED connector for few years now
      Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
      The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
      10-12-2025, 08:13 PM
    • perfm2
      Wson8 spring pin probe WORKS
      by perfm2
      I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
      I recently ordered one to give it a shot and it actually worked quite well.
      The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
      I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
      This aided greatly in allowing the probe to stay in place...
      03-30-2023, 11:19 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • vinayck
      ASUS UX481FLY Turns on sometimes
      by vinayck
      Might have some liquid damage (from > 1 year ago, was completely fine until a month ago) - unable to notice anything wrong easily on the motherboard (Core i7, GPU MX250, UX481FLY). I have cleaned parts of the motherboard with some oxidation with solder and flux - did not help.
      Laptop does turn on sometimes and is fully functional. However, while it is fully functional - (1) If rebooted, most of the times it enters a restart loop with blank screen (2) Sometimes, it crashes by itself and enters restart loop - with no relation to CPU/GPU load, heat, etc.
      I found that If I remove the...
      07-06-2025, 12:31 AM
    • mikey5791
      Tiny Tech ATX480W output power ticking
      by mikey5791
      Hi to all forum members,
      ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
      Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
      02-20-2025, 01:11 AM
