How to test bad capacitor with digital multimeter?
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Re: How to test bad capacitor with digital multimeter?
    Yeah well you said it, I am aware of these and the hundreds of clones of these things which have been around for a good decade if not longer. And not at all what I am looking for, currently until I can find something more suitable I will stick with my current testing method.
    • petehall347
      • Jan 2015
      • 4439
      if you have to pull one out to test it best replace with new .if project fails they arent too difficult to remove and throw into the box with the rest of the new pulls .
      • llonen
        • Sep 2014
        • 495
        • hampshire
        Your probably right there, most of the component pulls I make when servicing and repairing electronics are already known to me as bad. This is probably why I have yet to obtain a decent LCR / ESR tester, anything I do need to test more thoroughly I use a scope and function generator to do so. I was given a Peak Atlas component tester but despite it being an expensive one I dont think it does ESR.
          • 31199
          the peak does do esr - if it's the one for caps.
          what it wont show, unlike the chinese testers is leakage.
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • jinu_j
            How to test Subwoofer Amplifier with only a multimeter
            by jinu_j
            Hi Folks
            Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
            Problem
            I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
            Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
            Any advice would be appreciated...
            08-29-2024, 02:05 AM
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • chth96
            How Can I test PWM DM0365R?
            by chth96
            Hello
            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
            06-18-2025, 04:14 PM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
