Recommend a USB DAQ?
  • mathog
    • Mar 2010
    • 2655
    Every once in a blue moon I need something resembling an oscilloscope, but usually with 5 or 6 channels, portable, and with pretty minimal resolution and bandwidth requirements. A USB DAQ looks like it would fill the bill. It would plug into an old laptop (for now), so it has to work with USB 1.1. Also, ideally, it would have an open interface, so if need be I could program it.
    In other words, something like this:
    http://labjack.com/u3/specs
    but with a wider voltage input range. The latest problem is diagnosing an automatic transmission issue, where I need to simultaneously measure the PWM going to a couple of solenoids, and the DC signals coming back from 4 sensors. So it must measure up to at least 20V and also accept voltages well beyond that without blowing up the inputs. 10 bit resolution would probably be enough, but 12 would be better. A sample rate of 40 kHz should do. (I think. Anybody know what the base frequency is for the PWM waves fed to AT solenoids?) I don't expect to be able to use this for diagnosing motherboard waveforms, or anything else fast, just audio frequencies and down.
    It should also be cheap - this is for hobby use, so I can't justify a lot of $$$.
    Suggestions?
    In a couple of previous cases I was able to get by with making "recordings" using audacity from the audio input through a diode clamped adapter. That works OK for AC, but not at all for DC, and of course it was limited to two inputs.
    I did look through the oscilloscope thread here: https://www.badcaps.net/forum/showthread.php?t=6062
    but most (all?) of those needed to be plugged into 120/240 VAC.
  • mathog
    • Mar 2010
    • 2655
    Re: Recommend a USB DAQ?
    I ordered one of these:
    http://www.dataq.com/products/startkit/di149.htm
    Will report back on how well it works once it has arrived and I have had a chance to try it out some. This one was both inexpensive and it claims to be well protected from high input voltages, so hopefully I won't blow it up short of doing something really stupid.
    • tekguru123
      • Sep 2011
      Try USB data acquisition system from Futek Instruments. Just browse through their products at www.futekinst.com. Affordable and very easy to use. I've using their products for both laboratory use and as a hobby.
      • michelle827
        • Aug 2013
        • Taiwan
        I also used ADVANTECH USB. It has lots of different module, you can see which one suits you well! Though i think it's old software may have some bugsˊˋ...... but it's hardware is quit well. and i heard they are going to release a new version for bundle DAQ software. Hmmm... i think it will be better than the old one.
        You can see it's site to see what you need!
        http://www.advantech.com/products/Da..._1-2MLJZA.aspx
        • Tarot Superstars
          How not to Damage an Oscilloscope
          by Tarot Superstars
          Hello.
          I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
          I want to learn how not to damage it, and I found instructions on the internet obscure.
          They talk about ground, earth, floating ground, this, that....
          But they don't actually say anything anything useful so far.
          I want to know:
          Don't connect exactly this to exactly there or it blows up.
          For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
          I want to know what not to connect...
          08-29-2023, 02:27 PM
        • mostachio
          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
          by mostachio
          Hi Badcaps,
          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
          TV Details:
          Model # - TH-65DX700Z
          Symptoms:
          The television turns on and displays a picture then makes a clicking sound and turns off.
          I haven't opened it up yet but...
          09-04-2024, 02:32 AM
        • Evets
          Dynamco analogue oscilloscope
          by Evets
          I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
          08-30-2024, 06:54 AM
        • choucroutman
          Need help diagnosing why my TV isn't working anymore
          by choucroutman
          Hello, my LG OLED55C8PLA TV stopped working, and here's what happened:
          Around noon, it stopped turning on, meaning the screen stayed off, I heard a ticking sound when I tried to power it on, and the red LED light blinked 3 times. Afterward, nothing would happen for about 1 minute, and then the same cycle would repeat. A few days later, there was no more red LED blinking, and whether I tried turning it on with the remote or the power button on the back, it wouldn’t respond. I’ve tried some "quick fixes" I found online, like unplugging the TV and pressing the power button for...
          08-04-2025, 03:10 AM
        • SolomonMan
          Vintage BK Precision 1403 Oscilloscope....
          by SolomonMan
          All,
          Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
          Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
          I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
          12-03-2023, 10:39 PM
