20mhz scope enough to check receiver channels?
  • itek
    • Aug 2010
    • 65
    Hi everyone, I need to get a scope to test home theater receiver channels, but I don't have a lot of room (for a Tektronix).... Are these little hand held deals like an Owon HDS1021M good enough to check receiver amplifier channels? Thanks!
  • japlytic
    • Oct 2005
    • 2086
    Re: 20mhz scope enough to check receiver channels?
    What measurements (distortion, noise etc.) do you want to check on each channel?
    Some oscilloscopes can measure distortion and noise.
    • tron
      • Apr 2009
      • 47
      HDS1021M
      100MS/s sample rate
      no good
      Rigol DS1050E
      1GS/s Sample rate
      good
      • itek
        • Aug 2010
        • 65
        well I want to be able check output transistors and IC's,,, I guess maybe I should make room for a big boy machine
        • itek
          • Aug 2010
          • 65
          Well just to close out this thread I ended up getting an old Tektronix 465!
          Now I just need to learn how to use it to check for distortion and noise, etc..
          Thanks to all who helped
          • Longbow
            • Jun 2011
            • 623
            For all the uses I can think of, a 20MHz scope is more than adequate for troubleshooting audio equipment. I used an old HP audio scope for years that maxed out at 100KHz. The scope itself is not going to give you THD or IMD readings - its for signal tracing. The only thing I can add is that (as with any piece of equipment), you first have to know what signal you expect to be at a certain point before you go looking around. Have fun!
            Is it plugged in?
            • benspawn02
              Anthem MRX500 - no sound. R2A15218FP issue??
              by benspawn02
              Dear Electronics Experts:
              I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
              08-12-2023, 04:46 AM
            • wolf1976
              wireless receiver for 6 speeds fan control with remote control
              by wolf1976
              hi i have a receiver that is destroyed from the overvoltage i guess
              my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
              the motor fan has not label
              i have an other receiver operational
              In your opinion can i measure the voltage at the output ?
              what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
              thanks in advance...
              07-23-2025, 03:12 PM
            • repair-it
              Need advice testing a samsung power supply board with scope
              by repair-it
              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
              07-12-2025, 11:00 AM
            • sretchko
              Sony Receiver STR-4800SD L/R Balance
              by sretchko
              Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
              The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
              When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
              I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
              Badcaps Electronics Repair Forum & Schematic Search
              04-17-2024, 06:02 AM
            • CdDvdFlash
              DSE GE6878 possible TV receiver dying remote not working well
              by CdDvdFlash
              For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
              07-03-2024, 03:55 AM
