Sockets for component leads
  • jsog
    • Feb 2011
    • 220
    Ever since seeing that the Russian ESR meter had an IC socket for testing caps, I've liked that idea. Thinking about it, it should be something panel-mounted, sturdy, with deep sockets so a cap with uneven leads can be tested. There should be a row of pins for different lead spacing, or maybe just two slots.
    So far, the best thing I've come up with is a DB9F, but the female pins would have to be squeezed to touch a cap's leads reliably. Top five and bottom four pins would be wired together, just rotate the cap to fit across the two rows.
    Second best is a little solderless breadboard add-on piece, 2 rows of five holes. The few I have are meant to be mounted with double-sided tape, not very sturdy, and not flush.
    Any other ideas?
  • mathog
    • Mar 2010
    • 2655
    Re: Sockets for component leads
    Originally posted by jsog
    Any other ideas?
    Maybe a DC fan plug, the 3 or 4 lead type that plugs into a motherboard fan header? Probably the little springs inside will snap closed enough to make a decent contact on a capacitor lead. Use two of them, with all the leads in each twisted together, and it won't matter which hole in each header you use. Also with two of them the differences in the lead length on the test capacitor won't matter. You probably already have some on hand, attached to dead fans that have not yet been disposed of.
    • jsog
      • Feb 2011
      • 220
      A picture might help:
      • jsog
        • Feb 2011
        • 220
        Actually, I probably do have some of those, but would have to figure out how to panel-mount them. Solder them to a PC board that could be bolted in, maybe.
        • yyonline
          • Jul 2009
          • 692
          The ESR Micro uses a DIP socket. I haven't looked, but I imagine they'd be readily available on digikey and similar sites.
          Edit: something like this:
          http://search.digikey.com/scripts/Dk...rds=16-3518-10
          • jsog
            • Feb 2011
            • 220
            There are a couple of problems with a socket. The first is visible in this picture. The other problem is that the socket pins aren't really big enough for a slip fit on standard capacitor leads, even clean ones that haven't been unsoldered from a board.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5084
              • New Zealand
              The meters I've seen use blade terminals (?)
              -David VanHorn
              • APOPAP
                Panasonic National NV-M3 VHS Camera shuts down after some seconds
                by APOPAP
                Hello everybody,
                First post here. I have been reading posts here for some time now, but today I made my first account and post.
                The same question is also posted on another site, here it is:
                Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                08-25-2025, 10:12 AM
              • AlexForTheWin
                Help Diagnosing ASRock Taichi X570 Motherboard
                by AlexForTheWin
                Hi all! I'm a newbie to to the forum and electronics repair in general.
                I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
                I'd very much appreciate some guidance.
                Here are the steps I've taken to diagnose the board:
                I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
                Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
                12-16-2022, 11:37 PM
              • CG2
                Meaco Arete One / Deye Dehumidifier not working
                by CG2
                I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
                Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
                08-17-2024, 07:47 AM
              • Eh546
                Beginner, practicing to unsolder on a lead free xbox 360 board, it is hell.
                by Eh546
                Don't hesitate to tell me what i do wrong and if you have any tips and tricks, because i want to learn and improve.
                I have a 60w iron that can go up to 450c, cone tip, i usually set it at 400. I applied flux on solder, tinning the tip then applying new lead solder to the joint so that it can mix with the lead free and lower the melting point, then i tried to suck up the melted solder with the solder sucker. But that didn't work since the lead solder doesn't seems to mix with the lead free one. I also tried applying flux to a wick and the board, then tinning the tip of the iron and...
                05-24-2020, 06:59 PM
              • chj4591
                gddr5 ball lead?
                by chj4591
                gddr5 memory ball lead size?
                0.4mm 0.45mm 0.5mm​
                05-05-2025, 10:42 PM
