Basic Soldering Quesiton
  • obscurehero
    • Jan 2011
    • 26
    So, I recently re-capped a few problem capacitors on an old LCD monitor. I had bought all the capacitors to re-cap the whole board, just to be safe, but stuck with the problem capacitors because of a soldering issue.
    So, when I go to solder, I'll wash the tip on a wet sponge, and it's all nice and shiny. Then after I tin the tip briefly with some solder, the whole outer surface of the iron will turn a brownish/yellowish/blackish color as if its burning something in the air or oxidizing something. Then, those brownish flecks ended up making it into two of my solder joints. They didn't end up hurting the joint, but they didn't look nearly as pretty as the other 4 joints I made.
    Is there a way to avoid getting that brownish crap? Is it just a matter of soldering quickly after cleaning the tip? If its' just a speed thing, then I totally understand why i messed that up.
    Just so you know, I was using the CHIP-QUIK kit to de-solder the caps. I sucked most of the solder away with a de-solder pump, and then used de-soldering braid to get the solder that was left. I cleaned the joint with an IPA pad, and then soldered then new cap on.
    All the soldering was done, actually, in a clean un-used chemical fume hood at my place of work. I figured that environment would limit my smelling the solder fumes and have the least 'dust' or particulates in the air to get into my work.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Basic Soldering Quesiton
    that black stuff is usually the resin in resin core solder, its ok, if what you're talking about is what I think you are
    • obscurehero
      • Jan 2011
      • 26
      So, how do you limit the black stuff? Buy non-rosin core solder?
      • retiredcaps
        • Apr 2010
        • 9271
        Best soldering video is by CuriousInventor at
        http://www.youtube.com/watch?v=I_NU2ruzyc4
        And you don't need Chip-Quik for basic electrolytic caps. CuriousInventor also talks about Chip-Quik in another video here
        http://www.youtube.com/watch?v=FTQqjggeklo
        Of course, this site also has an excellent written soldering tutorial at
        https://www.badcaps.net/forum/showthread.php?t=485
        --- begin sig file ---
        --- end sig file ---
        • obscurehero
          • Jan 2011
          • 26
          I definitely used those resources previously, as someone suggested to me, and they were very helpful.
          My question is just in regard to the dark flecks that get into the solder joint on occasion. Seemed to be, like I described, that the iron would be nice and clean after wiping it on the wet sponge, but w/ or w/o the tinning the iron would quickly darken if not used promptly.
            master hoarder
            • May 2008
            • 12175
            That's resin/flux from the solder. Don't worry about it.
            What the resin/flux actually does is it "cleans" the surface where the solder is to be applied so then the solder can actually "stick" to that surface. If you used solder with no resin core, you would get very bad, dry-looking solder joints.
            The only way you can use a solder with no resin core is if you used liquid or paste flux. What you do then is you apply a coat of liquid/paste flux on the joints to be soldered, then you put solder on the joints. It still works out the same as rosin core solder, though.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              I don't usually notice flakes of black junk when soldering..
              What brand is your solder? Maybe you have some cheap one that uses substandard flux?
              Either way, you clean clean the flux etc off with flux remover, isopropyl alcohol etc (you should do this anyway)
              -David VanHorn
              • severach
                • Aug 2007
                • 1055
                The black flakes is the rosin after it's been heated for a long time. As you get better you need less heat and time to do the same work and the rosin won't burn to black flakes any more.
                sig files are for morons
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  Oh right... that must explain why I don't remember seeing it really
                  -David VanHorn
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • Nagyesz
                    Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                    by Nagyesz
                    I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                    All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                    How can I extend its lifespan? Could reflow help?
                    It has ryzen 5 5500h, rtx 2050, no soldered ram.
                    Example of the artifacts:
                    03-01-2025, 11:11 AM
                  • Geeker007
                    Friend messed up my laptop motherboard while working on my bench
                    by Geeker007
                    Hi All,
                    So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                    So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                    I have not tried putting...
                    06-16-2025, 01:40 PM
                  • tmhobadcap
                    Can a microwave oven be used to reflow solder joint?
                    by tmhobadcap
                    I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
                    Is that possible? I do not want to try this unless I have a spare microwave oven.
                    (I do not mean to suggest somebody to try this. It may be...
                    10-30-2020, 08:38 PM
