would you recommend desoldering wick/braid, if so recommendation on brand?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I never use a desoldering wick/braid before.
    I use a wellers ec3000 25w pencil soldering iron/station. It works well for what I need. I typically remove solder with using the "apply new solder to remove older solder" technique follow by using a mechanical sucker, which is great if you can get to the solder ball before it cools down or trying to share the space with a soldering tip. But from time to time, it gets a bit messy and sometimes I have to do it over again, or I successfully remove the component, only to watch the hole fill in with solder.
    So I was thinking... that a desoldering wick/braid would be more useful then a mechanical sucker. But I could be wrong.
    Your thoughts?
    Also if desoldering wick/braid would be good additional to my limited set of soldering tools, which brand or type should I buy?
  • mockingbird
    • Dec 2008
    • 5484
    Re: would you recommend desoldering wick/braid, if so recommendation on brand?
    Any brand is ok as long as its fluxed. Go to the hardware store, they sell small rolls of it for 2 and a half dollars. Should last you a while.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      I'm gonna buy some off digikey when I order my caps.
      Whats the difference between Rosin (Mildly Activated) vs Rosin Non Activated and which one should I get?
      • jbrittonjr
        • Feb 2011
        I use Chem Wik or Chem Wik lite if I have a choice and access to my toolbox.
        Otherwise it's whatever's available at the nearest Radio Shack.
        For fine printed circuit work you'll probably be happier with rosin coated wick.
        • ktmmotocross
          recommend good solder wick on aliexpress
          by ktmmotocross
          I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
          02-08-2024, 12:48 AM
        • estabilito
          Tips geting oxidized when using wick
          by estabilito
          Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
          i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
          Temperature: 350-365celsius
          station: jbc cd-2bqe
          Wick: edsyn
          flux: warton hf rework jelly
          Do you have any tips?...
          04-12-2025, 11:55 AM
        • hans_meier
          HP EliteBook 840 G6 how to dump without desoldering
          by hans_meier
          I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
          01-04-2025, 04:11 PM
        • Dreigas
          ISL95880HRTZ desoldering temperature
          by Dreigas
          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
          09-13-2024, 10:59 PM
        • armini
          18VDC PSU completely dead - ZD-915 desoldering station
          by armini
          Hi everyone!
          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
          Due to a lack of time, I set it aside and didn't look at it.
          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
          According to replies in 18VDC PSU has dropped to...
          04-25-2023, 07:49 AM
