optics for old eyes and electronics work
  • mathog
    • Mar 2010
    • 2655
    I have always been pretty near sighted (5.5D), which actually worked well for close up work when soldering and such. However, thanks to cataract surgery in both eyes I am now "blessed' with a left eye that focuses at about 2/3 of a meter and a right eye that is just a hair far sighted, with about .75D of astigmatism in both (at different angles). Today I did my first soldering job since the most recent operation, and it wasn't a lot of fun. No stereo vision, so I had to keep moving my head around to be sure the tip of the iron was where I thought it was. I do not yet have a set of prescription close glasses, so I had to use a magnifying glass to check all the solder joints. Also, of course, no accommodation courtesy of the fixed focal length of the intraocular lens.
    Some of you are likely in a similar boat and, to push the metaphor too far, have already learned how to sail it. What do you find works best for electronics work? Several pairs of glasses with different focal lengths, bifocals, trifocals, progressive lenses, those head mounted binoculars (like surgeons use) or ????
    Reading glasses would have been a nice inexpensive, easily obtained, solution if only my eyes were focused at the same distance and there was no astigmatism. However, I tried a bunch of pairs of these at the pharmacy and the resulting view, while having a closer focus, was pretty funky due to the lack correction for the astigmatism.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: optics for old eyes and electronics work
    Have you tried a good table mounted magnifier?
    I posted a thread about a mounted swing arm magnifier / fluorescent lamp about a year ago.
    Here's the thread:
    https://www.badcaps.net/forum/showthread.php?p=84711
    A well manufactured lamp that's ALL METAL not like those plastic made ones at Staples that break at the swing pin.
    While my vision is pretty good I find it really handy especially when inspecting for bridges after hand soldering SMD devices. It's near impossible to see fine bridges between the pins without magnification.
    It's near indispensable for finding solder cracks. Just pull it down and it hovers over your board and stays there so you can focus on looking and not holding a magnifying glass at the same length from the piece to keep the magnification.
    • PlainBill
      • Feb 2009
      • 7034
      That sounds familiar. Like you, I was very nearsighted, and was accustomed to removing my glasses to get a good look at close-up objects.
      I went through the surgery earlier this summer, although with slightly better results. I found that generic reading glasses work quite well for the close-up work. Because of another problem called divergence insufficiency I was fitted for prescription glasses with progressive bifocals. With those soldering is doable. You WILL have to develop a new set of reflexes, but it really doesn't take too long. I would suggest you discuss your requirements with the doctor who performed the surgery.
      In addition, I have a good quality (Luxo) lighted magnifier which I use for detail work.
      PlainBill
      • Stephen
        A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
        by Stephen
        Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
        05-29-2025, 10:35 AM
      • handsworth
        Tv taping method made easy
        by handsworth
        Just wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
        02-11-2025, 09:07 AM
      • Dannyx
        Looking to buy a microscope
        by Dannyx
        Good day and a belated happy New Year folks !
        Wow....feels like forever since I've had a chat with all the wonderful folks we got here - guess you could say I grew up and can look after myself now
        In all seriousness, I'm in need of some assistance choosing a microscope. I decided it's time I finally got one and I might as well put some of the money I earned caroling this year to good use
        The reason I'm turning to our community for advice is because I'd like to hear some thoughts from people who actually own a microscope already or at least worked with them hands-on,...
        01-09-2023, 01:16 PM
      • Zilicon
        Asus ROG ALLY RC71L schematics and boardview request
        by Zilicon
        Please, I need the above schematics and board view. I couldn't lay my eyes on any.
        the board number is NR2301L
        11-26-2024, 12:16 PM
      • ntchicken
        iPad Air [Generation 5 // A2588] No Power at All
        by ntchicken
        My iPad suddenly stopped working and does not turn on and is not detected by a computer. When I plugged it in and measured, it read the following:
        5V, 0.5A, 2.5W (both with and without a battery).
        I opened it up to look for obvious signs of damage but I can't seem to see anything with my untrained eyes. I took my multimeter, set it to continuity and tested the resistors and diodes for any shorts.
        Below, everything circled or boxed in yellow is shorted. Would anyone have any idea what the issue is based on the pictures and how to...
        09-26-2024, 11:13 AM
