macbook air A1932 stuck 5v and DFU mode
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i recieved dead macbook air a1932.. checked with usb amp meter only 5v 0.3A
    checked with apple configurator 2 shows DFU mode..try to revive but error 21. try to restore error 9 and now only show recovery instead of DFU in apple configurator 2..
    can someone help?
    thanks in advanced
  • Nash99
    • Apr 2021
    • 51
    • South Africa
    Re: macbook air A1932 stuck 5v and DFU mode
    Hi
    Error 9 usually occurs if there is a "block" somewhere stopping it from connecting with Apple's update server. The best bet is an external recovery.
    (1) Download a MacOS from the internet; (2) Make a USB drive bootable; (3) add the MacOS to the bootable USB drive; (4) boot the make using the bootable drive and recover from there.
    All data will the lost though.
    I hope this helps.
    • piernov
      • Jan 2016
      • 4439
      • France
      OP is talking about T2 DFU recovery not Internet Recovery.
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Originally posted by kingskie
        hi all,
        can someone help?
        thanks in advanced
        You need fast internet.
        Error like poor wifi
        2nd :update latest ibridge then check what happened.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          1. already using fast internet but still got error 9 when revive
          2. already using bridge os 5.5-18P4759a_Restore.ipsw (this is for mac os 11.5 but my imac mac os is 11.6..is it a problem?)
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            what i want to know now is why it is stuck on recovery instead of dfu because the first time i connect it showed DFU in apple configurator. so now how i change the recovery to dfu mode...can someone help?
            • Bb68
              • Jul 2017
              • 15
              • South Africa
              Hi Did you resolve ?
              • kingskie
                • Oct 2014
                • 249
                • indonesia
                not yet bro, do you have the same problem?
                • reassor
                  • Apr 2021
                  • 181
                  • Poland
                  dead t2?
                  hows the esd diodes on data lines?
                  there is a reason it was in dfu mode - you do not try to restore until you check wth is causing it.
                  • kingskie
                    • Oct 2014
                    • 249
                    • indonesia
                    Originally posted by reassor
                    dead t2?
                    still connected to T2 but in recovery mode, not DFU mode...before it can connect with DFU mode but after error when revive than it became stuck in recovery mode in apple configurator
                    • mferna14
                      820-01521-A (MacBook Air A1932 2019) stuck on 5V
                      by mferna14
                      Hi all dear friend., today I am working on 820-01521-A logic board (MacBook Air A1932 2019) stuck on 5V .19 milliamps. The history of this logic board was liquid spill on major components. First gave a good cleanup & both CD3215C00Z were getting very hot, so I replaced both. Now on the 12V coil, there is only 5v present & 3.3V is perfect. In some area like PPVIN_G3H_P3V3G3HRTC , PPBUS_G3H_TPAD etc., 12V is perfect. On the 5v coil .2 volts only. I checked the enable signal on the regulator chip, enable is NOT present. The logic board is very clean, I do not see any signs of spill anymore....
                      03-27-2025, 04:52 PM
                    • Junior†
                      Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
                      by Junior†
                      I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
                      here are my measurements/observations
                      with battery/fan connected (connected to 65W charger):
                      top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
                      bottom USBC port: 20V (80ma for a split second then goes to zero)
                      without battery, fan is still connected:
                      top USBC port: 4.950V (starts at ~75ma, then settles at 30ma)...
                      01-18-2024, 03:43 PM
                    • Instafixx
                      Macbook A1932 One Port stuck at 5v.
                      by Instafixx
                      I have a Macbook A1932 820-01521.
                      One port was drawing 20V and another port was drawing 5V. Machine did turn on.
                      Found corrosion near U3100 the CD3215 .
                      2 Resistors were missing. Cleaned and replaced them but still the same.
                      Reflow a few nearby components in that area in which i suspected corossion.
                      Is it a CD3215 fault. Is there any way i can check?
                      08-22-2023, 06:00 AM
                    • bouch
                      unlock macbook air A1932 2019
                      by bouch
                      hi
                      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                      I need help or information?
                      Does anyone have the minat2 activator 1.4 software?
                      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                      Thank yo...
                      03-12-2025, 10:14 AM
                    • mitchw
                      MacBook Air 2018 A1932 820-01521 stuck at 5V, but succesfully does the DFU and boots into OS installer
                      by mitchw
                      I have a 820-01521 that is stuck at 5V, and drawing just 230mA.
                      I did some troubleshooting, and managed to charge the battery up (was at 0%) using a different logic board.
                      Also I ran DFU and it did it successfully. Had to use a PMU_FORCE_DFU jumper to do it.
                      At this point the laptop started up and it successfully boots into the OS Install.
                      The charger is now at 20V, but drawing 0mA, so the laptop is essentially running off the battery. It doesn't detect the charger...
                      I think there could be a problem with one of the CD3215s, but all the LDOs are the...
                      01-04-2024, 01:47 PM
