Hi, I am working on an ASUS ChromeBook C434T, not powering on at all. The motherboard in it is C434TA_MB REV:2. Does anyone have the Schematics or Boardview for this model. The amp meter is stuck on 5v & does not turn on, no liquid spill., & it look clean, this model is with the USB-C charge ports. Any help will be great appreciate. Thanks
ASUS ChromeBook C434T not powering on, need schematic
Re: ASUS ChromeBook C434T not powering on
@LarrySabo - start a fresh thread in the laptop forum. This is an Asus so schematics are in the witness protection program.
However, perhaps you can locate the DCin connector -> post pics of the mosfets that follow and the charger IC onboard. Often, the fault is with the DCin mosfets unless there was some liquid or other damage to the unit.Comment
I had the same fault. I was able to fix it. The 3.3V converter and the usb control system were damaged. Everything works except the sound on the speakers (there is on the headphones). I am looking for a schematic or application for the max98927 chip.Comment
The laptop came to me dead - 5V on the power supply and nothing else. The LED does not light up, does not start, does not charge the battery.
A short circuit in the 3.3V line was caused by ANX7447 (3ohm relative to ground). After replacement, no short circuit but the chromebook still did not start. Replacing the TPS62125 converter restored proper operation. The PA (audio amplifier) is still damaged, after replacing +98927 the speakers still do not work. There is a burnt path from the chip that I can't locate - I need a layout app or a schematic for Chromebook Asus C434TAttached Filesif you find these attachements useful please consider making a small donation to the site
I have a C433t board with a different issue. I looked at the audio section and it matches your photo.The laptop came to me dead - 5V on the power supply and nothing else. The LED does not light up, does not start, does not charge the battery.
That burnt trace leads to the bottom of the left resistor in the area you circled.
If the system is still in your shop, hopefully this gives you audio back again.Comment
Thanks for the info, even though it's out of date. The identical PA works in some Xiaomi phones, I found a Redmi 6Pro diagram. In fact, this broken path connects one of the IC pins to ground through a 0 ohm resistor. Unfortunately, after repairing the connection and replacing the IC, the speakers still do not work. Headphones work.Comment
Does anyone know where you can obtain Asus Chromebook schematics and boardviews fromComment
It's all case by case, not a certain place to find ASUS Chromebook schematics and boardviews, they are spread all over the net & most are not even available. If you need a specific one, find on the net or this forum is the best to search for your needs.Comment
Hi guys, i have also this laptop for a repair... it's charging only at 5V 170ma, looking atthe board there is a broken component near the type-c connector
there is also another type-c at the other side of the laptop but i think it's not a charging port (or is it?) because it s not taking any milliamps
... one of the sides of the component is connected to ground , and the residual parts are black (resistor? diode?)
if someone can measure o identify if is a diode7resistor thank you!
here some images:Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks a lot for the info, I'm trying to help a friend repair the same model laptop with seemingly the same issue. I'm also measuring low resistance to ground on what I believe is the 3.3 V. How did you find out that the short circuit was in ANX7447? Just pure trial and error or was it getting hot or something similar? I'm seeing 5 V / 0.12 A but nothing seems to heat up. 3.3 V and 12 V converters seem to be working but the 3.3 V at the consumers gets dragged down to a very low voltage due to the almost short circuit to ground (I assume).The laptop came to me dead - 5V on the power supply and nothing else. The LED does not light up, does not start, does not charge the battery.
A short circuit in the 3.3V line was caused by ANX7447 (3ohm relative to ground). After replacement, no short circuit but the chromebook still did not start. Replacing the TPS62125 converter restored proper operation. The PA (audio amplifier) is still damaged, after replacing +98927 the speakers still do not work. There is a burnt path from the chip that I can't locate - I need a layout app or a schematic for Chromebook Asus C434TComment
Not sure if you're still working on this, but it's a diode exactly the same to the one to the right (and in the same orientation). I would guess it's for protection and not vital to the function of the laptop. See photo, sorry for the bad quality since it's taken through the lens of the microscopeHi guys, i have also this laptop for a repair... it's charging only at 5V 170ma, looking atthe board there is a broken component near the type-c connector
here some images:
For the record, the Chromebook I was trying to repair "magically" started to work again when I was trying to find which circuit was responsible for the almost short that I measured on the 3.3 V near ANX7447. I started by injecting 1 V/1 A from an external power supply, and the current consumption was very low, i.e. didn't seem like a short. When I upped it to 2 V/1 A from the external supply it suddenly jumped to 3.3 V, which I guess must've been coming from the battery, even though I suspect state of charge was low since it had been "dead" for several months. Anyway it went from being dead (no charge LED, only consuming 5 V/0.12 A from the USB) to booting. When booting I had a screen saying the OS was corrupted and needed to be restored, and when I pressed Tab I could see that it was caused by a TPM error. Performing a battery reset cleared that error and the laptop now seems to work normally. Very odd, I have no clue why injecting the external voltage made it come back to life. Anyway good thing that ANX7447 wasn't broken.
Hi All
New member here with a friend's C434T not powering on or charging. I suspect the battery is too flat for the charging circuitry to work and for some reason (probably safety, given what these batteries can do...) that prevents charging.
@y00kileet - please can you be more specific about where you injected the current?
I did wonder if it would be better to remove the battery for charging, when I did so I measure < 1V between red and black leads. I assume these are + and - battery connections - but I'd love to know if this is an appropriate place to start injecting charging current before trying it!
RichardComment
Hi guys. Help! I have two of these C433T dead. Only pulling 5V and 0.5A and other one is 0.1A I have thermal camera but can't see anything get hot. One I am finding caps shorted around this IC. I'm trying to learn laptop board repairs, would appreciate any help.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi All
RichardThis is a schematic request thread in the "Schematic Requests ONLY!" sub forum. Start a new thread here -> https://www.badcaps.net/forum/forumdisplay.php?f=23
Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
.Last edited by SMDFlea; 10-30-2023, 04:56 AM.Comment
by michalgI need a schematic or boardview for an ASUS Chromebook CB5500FE laptop. I want to program the Nuvoton NPCX797FC0BX microcontroller, and I don't know how the SWDIO, SWCLK, and nRESET signals are connected.
Channel: Schematic Requests ONLY!
07-20-2025, 04:22 PM -
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G boardview and ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 11:40 PM
by mferna14I am surprised that no one till today asked for a cleanup of this ASUS ChromeBook C423NA. The system runs Windows Critical updates in loops over & over again. I restored the Chromebook back to factory default. But still it runs Windows Critical Updates in Loops (Shuts down & starts Windows Critical Updates again & again). Can someone clean this BIOS. I have post the Original BIOS. Thanks Dear
ASUS C423NA-CB01-CB
SN: N7NXCV12927529B
CN: BE00
MFD : 2022-07
Motherboard #: C223NA MAIN Board Rev:2.2
Sticker on the board: PN: 60NX01Y0-MB1401 C423NA...-
Channel: BIOS Requests ONLY!
by JoshwaHello, please i need a schematic for my Asus ROG G703GI laptop.. I think my motherboard has a problem with the sound. Thank you!!
10-16-2025, 06:21 AM -
- Loading...
- No more items.
