Sharp LC-60LE810UN Lamp Error
  • Yanleb
    • May 2017
    • 101
    I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
    I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
    Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
    I've tried all the key combinaisons I've found in the forums and in the service/training manuals to bypass the Lamp Error mode and nothing works. The TV sets just continue to flash the Lamp Error code.
    Here are the voltage measurements on the power supply board at the connectors going to the main board:
    PD:
    1-2: UR13.2V(Signal) : 0 volt
    3-4: S13.2V(Signal) : 0 volt
    5-6: GND(Audio) : 0 volt
    7-8: GND(Signal) : 0 volt
    9: AC-DET : 0 volt
    10: PS-ON : 0 volt
    11: BU5V : 5 volt
    12: PNL-POW : 0 volt
    LB:
    1, 4, 5, 9: NC : 0 volt
    2: Dimmer : 0 volt
    3: GND : 0 volt
    6: ERROR : 0 volt
    7: OFL : 0 volt
    8: STB : 0 volt
    I used a DSO scope in single trigger mode and I can assure you that all the pins on the two connectors stay at 0 volt no mater what I do on the TV (disconnect then reconnect the AC cord, press all the key combinaisons both without and with the AC cord disconnect). Only BU5V has 5 volt.
    Even if the defective LED strip is not repaired, you must admit that the TV set must at some time power on, even for a split second, to test the LED strips. It has no choice, it is impossible for it to detect a repaired LED strip without sending it power.
    At some time I doubt about the capacitive touch keys at the front of the TV set. Using my scope I monitored the I2C communication pins (SCL and SDA) and each button has generated a signal at the main board.
    I'm kind of lost on that one. I've read all the forums on the Lamp Error for the LC-40LE810UN, the LC-46LE810UN, the LC-52LE810UN and the LC-60LE810UN TV sets (even those on the 820 models) and nothing helped me to power on the TV set and get to the service menu to reset the Lamp Error counter.
    I hope someone will be able to help me. Thanks in advance.
  • Yanleb
    • May 2017
    • 101
    Re: Sharp LC-60LE810UN Lamp Error
    Anyone with an eeprom dump for the KF452 main board? I think this will be the only solution to get out of the Lamp Error mode.
    • diif
      • Feb 2014
      • 6978
      • England
      Have you replaced the LED strip ?
      • Yanleb
        • May 2017
        • 101
        Not yet. As I said I want to make sure the TV will power on first.
        I did put a DSO scope in single trigger mode on the PS-ON, PNL-POW, OFL and STB terminals and the main board never tried to power on the power supply/backlight.
        It is impossible for it to detect the eventually repaired LED strip if it never power it on first. If I can get the main board to turn on the power supply even for a split second then I'll invest money and time to fix the defective LED strip.
        • diif
          • Feb 2014
          • 6978
          • England
          It won't until you replace the strip. The TV turns on, detects a lamp error and puts out the error signal.
          • Yanleb
            • May 2017
            • 101
            The ERROR terminal stays at 0 volt all the time since the power supply is never turned on, not even a millisecond. So the main board is unable to know the actual condition of the LED strips if it doesn't try to test them. The main board doesn't have a crystal ball.
            • Yanleb
              • May 2017
              • 101
              This one is fixed. Even after repairing the backlight LED strips (it had one open LED that I simply bypassed), the set would not turn on. It was keeping flashing its lamp error code.
              As I said, the TV does not even try to turn the backlight on. I proved that with a scope with a single shot trigger. So it is impossible for it to detect the repaired backlight. None of the lamp error reset procedure worked.
              Even if the service manual doesn't include a complete schematic, it at least includes a block diagram. On the block diagram we can see that the lamp error is handled by a microcontroller at position IC2002.
              This microcontroller has an EEPROM attached to it (IC2004). This EEPROM is marked 402m 40b2 and is in fact a 24c02 compatible I2C EEPROM. The Sharp part number is VHiR24002AS-1Y and is a Renesas R1EX24002ASAS0A 256 bytes EEPROM.
              I removed the IC2004 EEPROM from the board and I erased it using my TL866II-Plus programmer. I then put it back on the main board. Bingo, the set powers on on the first try.
              So, if you have a lamp error that you cannot clear after the repair, just erase the IC2004 EEPROM located under the main board. If you don't have an EEPROM programmer, just buy a blank R1EX24002ASAS0A and install it on the main board.
              • jimbofz
                • Apr 2013
                • 539
                • uk
                Hi i read your post with great interest can you tell me how to identify replacement eeprom for S64 9K75 used in sharp lc 40le600e
                please see my earlier recent post
                sharp LC40ELE 600E standby only faulty backlight
                cct diagram shows ic8455 eeprom ,as br24s64f
                no luck with google finding one
                i want to remove original and fit a blank one
                i do have a CH341 programmer and can wipe the original data
                and resolder it back in
                but would prefer to leave original one programmed ,in case fault is not eeprom corruption
                • DevAlexOne
                  • May 2023
                  • 1
                  • Veracruz
                  amazing
                  • Eric D.
                    Sharp LC-60LE810UN Lamp error
                    by Eric D.
                    Hello everyone!
                    I just acquired a Sharp Aquos for free.
                    When I plug it in, it will try to power on, but it fails.
                    The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
                    I did a bit of research and did what I found could be the possible issues;
                    I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
                    I also tested the leads going into the psu board from the wall connector; I get 120V.
                    I disconnected...
                    01-18-2025, 05:14 PM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • Superbee_dad
                    Sharp 80” long short flash backlight error - Help
                    by Superbee_dad
                    Hello Sharp TV experts
                    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                    01-24-2025, 11:51 PM
                  • adelage
                    220v Led strip flickering
                    by adelage
                    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                    I know that the best solution would be to get a voltage...
                    11-03-2024, 09:49 AM
                  • benareeno
                    Adjustable dc power supply and tcl led strip
                    by benareeno
                    I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                    I have an adjustable dc power supply and was trying around 9 volts.
                    I have a pic of a single diode...where to put pos and neg terminals to light it up?
                    Pic of middle of strip..is this where i light the entire strip?
                    And pic of end...or does this light the entire strip?
                    Where to put pos and neg for single diode..multiple diodes and the entire...
                    07-11-2021, 02:31 PM
