can i replace sy8288b with SY8288crac?please help
ic pin compatible sy8288b with SY8288crac
Re: ic pin compatible
Look here at the silergy marking list - https://www.badcaps.net/forum/showpo...23&postcount=1 .There`s no datasheets available but there is a few schematics available to check the pinout.
BAB*** SY8288BRAC - N/D (LA-F611P)
BAC*** SY8288CRAC - N/D (Quanta ZHP ZSP)
https://www.badcaps.net/forum/showth...light=LA-F611P
https://forum.laboneinside.com/viewtopic.php?t=11026
check the pin config carefully before you decide if its compatible or notLast edited by SMDFlea; 05-15-2021, 04:45 AM. -
Re: ic pin compatible sy8288b with SY8288crac
thank you smdflea i check is not the same pin is differentComment
Hello, sorry for the English, I helped myself with a translator, here is a list of replacements, best regards.Comment
We all contributed to insanemotherboards to create that list, even Jonathan Veliz has the list posted and has it constantly updated, how ugly that you attribute the merit to yourself when the entire Latin American if not the global community has been part of it, greetings!
todos contribuimos en insanemotherboards para crear ese listado, incluso jonathan veliz tiene la lista posteada y la tiene actualizada constantemente, que feo que te lo atribuyas a ti el merito cuando toda la comunidad latinoamericana si no es que mundial hemos sido parte, saludos!
by NotEnoughHi everyone,
I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
What I've Tried So Far:- Reseated the cables.
- Reinstalled AWCC and AlienFX services.
- Attempted BIOS downgrade but no improvement.
- Inspected ribbon cables for damage.
- Explored the possibility of BIOS or
by Deby
This is a list of compatible laptop motherboard information that I have been collecting for some time.
And it's still ongoing.
Every time I come across information that a board is compatible with another, I write it down.
Anyone who wants to, can continue to expand the list.
Packed in the rar, is an excel table that has additional information.
Motherboards.rar...05-31-2024, 04:34 AM -
by zwectI got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...07-21-2025, 05:53 PM
by PeeripapoHi All,
so I got an Asus g752vt and the USB C (Thunderbolt) port is broken. I need to find a compatible replacement for that.
Are all USB C conectors the same or do I need to get a specific one for that board. The USB port brand is LOTES and it has the 1546 number on top of it. Where can I Find a similar one ?
[COLOR=hsl(var(--text-300)/var(--tw-text-opacity))]
[/COLOR]...1 Photo -
by badcappoHi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
Thank you...
- Loading...
- No more items.
