ic pin compatible sy8288b with SY8288crac
  • String2016
    • Nov 2015
    • 2242
    • philippines
    can i replace sy8288b with SY8288crac?please help
    • 22424
    Re: ic pin compatible
    Look here at the silergy marking list - https://www.badcaps.net/forum/showpo...23&postcount=1 .There`s no datasheets available but there is a few schematics available to check the pinout.
    BAB*** SY8288BRAC - N/D (LA-F611P)
    BAC*** SY8288CRAC - N/D (Quanta ZHP ZSP)
    https://www.badcaps.net/forum/showth...light=LA-F611P
    https://forum.laboneinside.com/viewtopic.php?t=11026
    check the pin config carefully before you decide if its compatible or not
    • String2016
      • Nov 2015
      • 2242
      • philippines
      Re: ic pin compatible sy8288b with SY8288crac
      thank you smdflea i check is not the same pin is different
      • jebadoss
        • Oct 2015
        • india
        pls tell me the equivalent ic for sy8288rac
        • deepak47
          • Jul 2017
          • 13
          • India
          TPS 51395 is compatible with sy8288crac
          • henrytronics
            • Jan 2020
            • peru
            Hello, sorry for the English, I helped myself with a translator, here is a list of replacements, best regards.
            • adin
              • Aug 2021
              • 39
              • australia
              thanks for datasheet
              • punkrockpax
                • Feb 2019
                • 32
                • Mexico
                todos contribuimos en insanemotherboards para crear ese listado, incluso jonathan veliz tiene la lista posteada y la tiene actualizada constantemente, que feo que te lo atribuyas a ti el merito cuando toda la comunidad latinoamericana si no es que mundial hemos sido parte, saludos!
                We all contributed to insanemotherboards to create that list, even Jonathan Veliz has the list posted and has it constantly updated, how ugly that you attribute the merit to yourself when the entire Latin American if not the global community has been part of it, greetings!
                • Sha321
                  • May 2021
                  • 9
                  • India
                  BABBCE . NEED IC DATASHEET
                  • Deserves
                    • Oct 2024
                    • 20
                    • French Polynesia
                    can tell me what IC was compatible with SY8288BRAC
                    • danilo674@hotmail.com
                      • Apr 2023
                      • Tuxtla Gutierrez
                      IC Compatibles: SY8286DRAC (BAA) = JW5068A =JW5069A
                      • byrlopez
                        • Feb 2011
                        • 47
                        Hi everyone, BAB = SY8288BRAC can also be replaced with AWV = SY8286B. I just replaced it on a Dell Latitude 5300 2-in-1 18717-1 and it worked.​
                        • RotVik
                          Learning...
                          • Feb 2016
                          • 57
                          • Mexico
                          Link?
                          • NotEnough
                            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                            by NotEnough
                            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                            What I've Tried So Far:
                            • Reseated the cables.
                            • Reinstalled AWCC and AlienFX services.
                            • Attempted BIOS downgrade but no improvement.
                            • Inspected ribbon cables for damage.
                            • Explored the possibility of BIOS or
                            10-19-2024, 01:34 AM
                          • Deby
                            List of compatible laptop motherboards
                            by Deby
                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                            And it's still ongoing.
                            Every time I come across information that a board is compatible with another, I write it down.
                            Anyone who wants to, can continue to expand the list.
                            Packed in the rar, is an excel table that has additional information.
                            Motherboards.rar...
                            05-31-2024, 04:34 AM
                          • m4a2t0t
                            BD35231 compatible replacement
                            by m4a2t0t
                            Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
                            Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
                            Thanks for any help...
                            08-28-2025, 08:32 PM
                          • taurtnt
                            Help identifying AMCH073 regulator or finding a compatible replacement
                            by taurtnt
                            I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
                            Here’s what I’ve observed:
                            • It has a QFN-16 footprint, similar to NB670.
                            • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
                            • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
                            • Pin 8 also seems to be tied to the same GND plane.
                            • The chip only says AMCH073, no manufacturer logo or other markings....
                            08-24-2025, 03:06 PM
                          • zwect
                            RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
                            by zwect
                            I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
                            07-21-2025, 05:53 PM
