Finally built the Bob Parker "Blue" ESR Meter
  • jayjr1105
    • 281
    Have wanted to build this for a long time ever since I saw Dave Jones use the old black and red one. It was fun to build and works great. What ESR meters do you guys use?
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Finally built the Bop Parker "Blue" ESR Meter
    There have been a few threads about this meter in the past if you want some history.
    I still have mine, and I used it today at work!
    Sure I have a couple of the Atmega based "transistor testers" that are all over eBay.
    But this original Bob Parker design is special to me, I really like it!
    https://www.badcaps.net/forum/showthread.php?t=1287
    https://www.badcaps.net/forum/showthread.php?t=6535
      • 31259
      Re: Finally built the Bob Parker "Blue" ESR Meter
      i didnt even know the Anatek blue was still being sold!
      • jayjr1105
        • 281
        Oh wow, the Bob Parker lurked on these forums, cool!
        I love it. Just waiting on better probes. Wish the blue meter had the banana jacks like the old Dick Smith model had. Otherwise It's great and was fun to assemble.
        Ryzen 3600x
        FX-8802 Iron
          • 31259
          you could re-drill the endplate and fit a couple of 4mm shielded sockets.
          • jayjr1105
            • 281
            They actually give you an extra endplate without any holes, I guess in case you want to do something like this. You'd have to re drill the hole for the power button but that's not difficult.
            Ryzen 3600x
            FX-8802 Iron
            • redwire
              • Dec 2010
              • 3912
              The Blue ESR Meter works great for me, it just plain works with no hassles and a good investment.
              The Zilog Z8 MCU is obsolete and I wondered about the kit's supply.
              I wanted to write firmware take the concept over to a newer MCU and find a way to add an extra digit, and read capacitance as well.
              • jayjr1105
                • 281
                Is the original code used for the Z8 closed source?
                Ryzen 3600x
                FX-8802 Iron
                  • 31259
                  i think so.
                  • bcstedt
                    • Jun 2011
                    • 59
                    Thanks for the update and the pics!
                    I mostly use the Blue ESR (rev 1) and the DE-5000 (ver 8). I just got looking over the Blue ESR docs and found the self test section (it's been a long while) but have now found my meter is giving an FA error code. Can anyone else confirm their self test is working okay (.8.8 display)?
                    I've never noticed anything really 'strange' about the behaviour of my Blue ESR but now I'm curious. :/
                    From the manual:
                    Switch the meter on by pressing and continuing to hold the button down, regardless of what the displays are showing. After five seconds, they will go blank for a moment and then show a test result for two seconds. The meter will then switch off by itself after you release the button.
                    If everything is more or less OK, you’ll see “.8.8” on the displays (this shows that all the display segments and decimal point LEDs are working). However, if the microcontroller has detected a problem it will flash a fault code
                    consisting of an “F” on the left hand display and a character from 0-9 or an “A” on the right hand one.
                    FA: Q6 not switching on. Check around Q6 (2N3904), R24 (10kΩ) and pin 1 of IC2.
                    The microcontroller cannot perform detailed tests on every component, so it’s possible that your meter is malfunctioning even though the self-testing hasn’t shown up a problem. For example, if the meter is behaving strangely, “freezing” up or giving absurd readings on some values of test resistors, the most likely cause is a mix-up in the values of R6 (10kΩ), R8 (1kΩ) and R10 (100Ω). On the other hand, if the meter produces readings but there’s something wrong with the displayed characters, this is almost certainly due to one or more solder bridges between the pins of the displays or around IC3.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Mine (an original Dick Smith Electronics K-7214 MK2) shows 8.8 for the self-test.
                      It could be that Q6 has been damaged from a charged capacitor.
                      You can check the area around it and ultimately try to replace Q6.
                      • bcstedt
                        • Jun 2011
                        • 59
                        I've inspeced the board, checked the battery and voltage while running, reseated the Zilog (IC2) but no change. A damaged Q6 seems like a reasonable explanation I'm just surprised. :|
                        • redwire
                          • Dec 2010
                          • 3912
                          The Blue ESR meter firmware does show fault codes for many problems:
                          F0- Q11 not discharging Q10.
                          F1- C10 charging too fast.
                          F2- C10 charging too slow or not at all.
                          F3- Pulse amplifier bias Q8-C <0.44V
                          F4- Pulse amplifier bias Q8-C >1V
                          F5- Test current source is always on.
                          F6- Pulse amplifier has no output.
                          F7- Q3 not sourcing current.
                          F8- Q4 not sourcing current.
                          F9- Q5 not sourcing current.
                          FA- Q6 not switching on.
                          FA might be the input protection diodes D3 or D4 shorted. Those fail if you connect the unit to a big charged cap. Less likely the 22uF BP cap C6 has gone open.
                          • jayjr1105
                            • 281
                            Bought some cheap modular probes for mine. Thinking about soldering in some thicker/longer wires into it, the ones that came with this probe kit to be exact. Probably don't want them too long right?
                            Ryzen 3600x
                            FX-8802 Iron
                              • 31259
                              huge probes!
                              i have several of these - i get a pair for every meter!
                              https://www.aliexpress.com/item/32848907433.html
                              • bcstedt
                                • Jun 2011
                                • 59
                                Q6, D3 and D4 are not shorted and seem to test ok in circuit.
                                C6 measures 22uF in both directions, also in circuit.
                                Prefer not to remove components until I have a better idea what's going on. Maybe I'll see if I can contact Bob.
                                • bcstedt
                                  • Jun 2011
                                  • 59
                                  Those look pretty neat especially for the price. Do you use this seller specifically?
                                  • bcstedt
                                    • Jun 2011
                                    • 59
                                    Component locations for those playing along.
                                    • jayjr1105
                                      • 281
                                      Probemasters are some of the best probes you can buy and they are like $15 shipped. Highly recommend them.
                                      Ryzen 3600x
                                      FX-8802 Iron
                                      • jayjr1105
                                        • 281
                                        huge probes!
                                        Not a ton of options when you need modular ones that will accept 4mm banana plugs.
                                        Ryzen 3600x
                                        FX-8802 Iron
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
