Panasonic TX-L55WT50B
  • comptek
    • Aug 2013
    • 606
    • uk
    Hi guys hope you are all well
    Hoping there are some Panasonic specialists about I have the above model
    Tx-l55wt50b I have looked for a schematic of the power supply and couldn’t find one even the service manuals only cover everything else but the psu.
    Anyway I got the tv and it was making a loud buzzing noise from the back opened it up and found that IC571 / 2A fuse / a couple of zeners on the back had blown
    Power supply CT31004 U84PA-E0011754B
    Replaced IC571
    Replaced fuse with a temp 2A wire
    I had zeners in place but probably wrong as when I plugged it in all that happens is the red light flashes 3 times pause 3 times pause and so on.....
    Position ZD571 was a G5 zener I think I found an equivalent?
    Position ZD572 Empty had a zener there that was short
    Position ZD552 Found to be shorted too
    Can anyone point me in the right direction of the values/ Equivalent or a manual for the power supply
    Thanks in advance
    Gary
  • comptek
    • Aug 2013
    • 606
    • uk
    Re: Panasonic TX-L55WT50B
    Here are some photos
    • R_J
      • Jun 2012
      • 9582
      A 3 blink sos refers to an "A" board fault, Was there a number on IC571?
      • comptek
        • Aug 2013
        • 606
        • uk
        Hi RJ, there was a number that I had to clean off the black glue to find and piece together it was FSFR1700XSL I purchased two just in case...
        I need to get the power supply back to standard before I can test anything else
        When I got the 3 flashes i set out to find some zener diodes, it was then when I took the diode off of the lower side to test it that I found it it was short so that may have caused the 3 flash sos
        • comptek
          • Aug 2013
          • 606
          • uk
          Hi guys any other help available
          Schematic diagram of power supply?
          Approx values of zeners ?
          Thanks in advance
          Gary
          • Diah
            • Feb 2013
            • 6425
            f you upload a complete photo of yours PSU from both side. and remark the area you have short on it will be more essential, because from my know early Panasonic TV PSU used same main diagram to build any further versions. so any early Panasonic psu boards will give the answer on any missing mysteriously parts.
            • R_J
              • Jun 2012
              • 9582
              I'm not sure if this will help, but this Samsung power supply uses the same ic. The BN44-00498A uses it as well.
              The ZD572 seems to be between Lvcc and ground, so I suspect it is just for over voltage protection. IC lvcc max is 25v so it could be a 18~20v zener
              ZD573 is on the CS, current sense line to ground, this pin sees a very low negative voltage so I would guess a zener of around 4.7v or maybe less?
              • comptek
                • Aug 2013
                • 606
                • uk
                Hi guys I fixed it
                I replaced the faulty zener diodes with what work out to be 4.5v ish and it's working now all there was 3.2volt and 5 volt that was all
                Now all voltages are up
                Crikey wow what a picture on it I'm going to run it for a couple of days
                • R_J
                  • Jun 2012
                  • 9582
                  Are you sure you used a 4.5v zener for ZD572 & ZD552? That is the Lvcc line and should be around 12 volts
                  I can see 4.5v for ZD573 & ZD553 but not ZD572 or ZD552
                  • comptek
                    • Aug 2013
                    • 606
                    • uk
                    I will double check R J but it's been on all day I keep switching it off and back on and it seems fine at the moment
                    Regards
                    Gary
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • nev1001
                      What zener diode might fix the sound on Maestro Mayhem gaming chair?
                      by nev1001
                      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                      I think an issue could be a zener diode (or capacitor) which has shorted out.
                      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                      04-17-2025, 05:09 PM
                    • AquaMan Ua
                      Problem with PANASONIC CF53 laptop after changing BIOS settings
                      by AquaMan Ua
                      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                      05-17-2025, 09:40 AM
