Dell G3 3579 Bricked BIOS / KB Fix
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Was trying to fix a Dell G3 3579 that had slow kb and no battery charging issue after BIOS update to v14. Tried loaded v13 BIOS using /forceit command (since battery was under 10%) which resulted in a bricked computer. A dump of the BIOS is attached.
    I tried flashing the BIOS posted by SMDFlea in a recent post from someone else with the same model who was also trying to fix kb issue and it does post with that BIOS but fans go full blast and it shuts off after about 5 seconds. Maybe that model had slightly different specs.
    Any help much appreciated.
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Re: Dell G3 3579 Bricked BIOS / KB Fix
    In the interest of clarity, the BIOS dump is from after I tried the /forceit command to downgrade to v13. I didn't have the foresight to dump it before trying that sadly.
    • peste
      • Dec 2016
      • 13199
      • ROMANIA
      try..
      • pehol193
        • Oct 2019
        • 8
        • Poland
        This dump doesn't work for me. The problem with the computer the same. After bios update due to bad keyboard. the computer has stopped charging the battery. the power supply does start / stop on / off
        • mgrharry
          • Sep 2016
          • 211
          • usa
          Thanks for the try, peste, but unfortunately it doesn't post at all with this.
          • peste
            • Dec 2016
            • 13199
            • ROMANIA
            try post #5..
            https://www.badcaps.net/forum/showthread.php?t=84189
              • 21467
              In the dell bios update there are 2 EC firmwares,ME Firmware and a 9MB bios update. The 2 EC files are different, 086F is EC 1 ,and 0870 is EC 2 .The 9MB bios update contains EC 1. There`s another thread with a bios that has the 0870 EC 2 FW - https://www.badcaps.net/forum/showth...highlight=3579 See post #1 ,"oryginal no video.rar" is the one.
              So does that laptop have a different spec to your model,or is it the motherboard revision number ? ,who knows. Is the bios update flashing the wrong EC ? ,surely dell wouldn`t do such a thing ,but microsoft would.
              Try the attached bios, the first has the 1.14 bios update merged and the 0870 EC 2 ,+ clean ME FW but no service tag or win key. The second is just to test, its the same as the first but with the service tag and key.
              • mgrharry
                • Sep 2016
                • 211
                • usa
                Ahh brilliant! Post, kb and charging issue are fixed. Went ahead and flashed TEST2 version with ST and key. Secure boot does fail validation however, but if I turn it off I can boot without issues. Any idea what that's about?
                Disabled UEFI firmware capsule updates to prevent Windows from "helping out" with a BIOS update in the future.
                • trceyhan2606
                  • Aug 2021
                  • 1
                  • Turkey
                  Hello sir, what should i do with these bios files. Should i try to flash them with an usb? Please help...
                    • 21467
                    Have you tried dell bios recovery,try it first . https://www.dell.com/support/kbdoc/e...uter-or-tablet
                    To flash the files posted here you will need an SPI programmer
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      Hi the board was working but after changing its keyboard the fan spins fant no display light indicator has 3 orange 1 white it says rtc battry failure, I already tried cahgning its battery with a new one also. What maybe the problem
                      • NhlalukoG
                        • Aug 2022
                        • 1
                        • South Africa
                        Which BIOS fixes the no charging issue. I've been using my laptop battery less for close to two years now, bought a battery, worked fine but didnt charge.
                        No issues at all it just doesnt charge... bought an SPI Programmer, coming in soon, just need to know in which BIOS things went south
                          • 21467
                          If your old battery was working ok and charging theres nothing wrong with the bios. If the battery you bought is genuine and not fake then contact the seller for a replacement. If you bought a "compatible" one,then i`d also ask for a replacemnt or a refund,there`s lots of shitty batteries in the marketplace.The best ones without a doubt are genuine ones.
                          • O.Szilard
                            • May 2019
                            • 161
                            • hungary
                            Thank you, I programmed the first file, the machine works perfectly! Thanks!
                            • wacd
                              • Jun 2014
                              • 37
                              I'm experiencing similar problem with LA-K033P , device has 3 different models listed in the bios version. 0A23,0A24,0A25. After windows update, keyboard gone crazy. Right side of the KB presses multiple keys while the left side from the middle works fine.
                              How do i incorporate different EC versions into the original bios i dumped from the mainboard? Can you please share some information ? SMDFlea
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • DavidChunco
                                Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                by DavidChunco
                                Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                - Receive help from Dell Support (it is out of warranty).
                                - Disconnect machine from AC power and battery overnight.
                                - BIOS recovery process
                                - Connected external display via HDMI
                                - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                03-15-2025, 11:00 AM
                              • trix11
                                Dell Precision T1650 MT Workstation bricked after BIOS update
                                by trix11
                                I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                - Dell Precision T1650 mid tower Workstation
                                - Xeon E3-1225 V2
                                - 32Gb PC3-12800E RAM
                                - 4Tb SATA HDD
                                - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                I see now that others have experienced like issues e.g.:
                                - https://www.dell.com/community/Prec...
                                10-24-2022, 10:35 PM
                              • ezenia
                                Dell G3 3579 BIOS chip ID
                                by ezenia
                                I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
                                06-16-2025, 08:07 PM
                              • mikeybass
                                Dell 9010 MT BIOS Update Always Fails
                                by mikeybass
                                Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                04-23-2025, 04:30 PM
