GL72 6QF, MS-16J51 me region 0.0.0.0 , powers off
  • rookieme
    • Oct 2014
    • 397
    • Greece
    I have a msi notebook that had burned southbridge and I replaced it.
    As before in order to work I reprogrammed bios with original from MSI.
    It works but at bios I can see me region is blank [0.0.0.0] and so it powers off after 30 minutes.
    Is there a workout with the new bios to make it work?
    I have attached original bios [old.bin] and the latest from msi [E1795IMS.11D]
    Thank you
    • 31063
    Re: me region 0.0.0.0 , powers off
    the me is probably blank because you cant dump it with software - only a chip programmer.
    maybe you can fix it with me-cleaner to not need one
    • piernov
      • Jan 2016
      • 4436
      • France
      Should be in https://www.badcaps.net/forum/forumdisplay.php?f=23 .
      After replacing PCH you should just clean ME region (properly using Intel FITC) in the original dump.
      The image from MSI seems to contain the full ME region so it should work too though.
      Could be an issue with the ME disable strap, the replacement PCH or its soldering.
        • 31063
        maybe the bios isnt happy with the code in the KBC
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I believe that, with those apparently "smart power controllers". Just another thing to go wrong, IMHO!
          Maybe this is why some new ATX motherboards have a power-cycling fault! (Which would be a KBC or equivalent. Possibly known as an embedded controller on ATX motherboards)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • rookieme
            • Oct 2014
            • 397
            • Greece
            thank you all for your replies
            @piernov
            as this is something I have done before again I agree that the image from MSI should work.
            I am guessing that this could be an issue with the soldering as you mentioned and confirmed my fears so I'll reball and inform for the results.
              • 21031
              Did you get the PCH from a donor board,if so what make/model and motherboard part number
              • rookieme
                • Oct 2014
                • 397
                • Greece
                it was bought from a trusted seller in Shenzhen
                • piernov
                  • Jan 2016
                  • 4436
                  • France
                  As long as it's the same sSpec and it doesn't look cooked too much it should be ok.
                    • 21031
                    Besides the points already made by piernov its possible that the PCH you bought has boot guard enabled in it or some other settings, it depends exactly what board it came from as its most likely a reballed chip rather than brand new ?
                    The Intel PTT power-up state is disabled in your backup, and its enabled by default in the stock bios, i don`t think that would be an issue but you can try the attached bios,also there`s an ME updater on the MSI support page with a stock ME region,https://www.msi.com/Laptop/support/GL72-6QF ive used the same ME FW version but used PRD RGN, and disabled Intel PTT power-up state.
                    Before flashing the bios its worth trying Flash Programming Tool with the command -greset to force the PCH to accept the settings from the bios ME FW ,if that doesn`t work try the MSI ME updater,it will update the ME and force a reset.
                    • rookieme
                      • Oct 2014
                      • 397
                      • Greece
                      Thank you for the new tools and bios.
                      So far I have used an external programmer and the update bios opion from bios menu.
                      I have already tried the MSI's ME updater but didn't work as system does not meet all conditions [blank ME I guess]
                      All these are new to me but will try them before messing with SB again.
                        • 21031
                        Do you have the ME driver installed . https://download.msi.com/nb_drivers/...1.0.5.1189.zip
                        • rookieme
                          • Oct 2014
                          • 397
                          • Greece
                          Update:
                          I tried command -greset but I guess it's the same with removing all power sources for 1 minute as I had already done.
                          after I tried the flash bios with command FPTW64 -f outimage.bin and got the error
                          Error 368: Failed to disable write protection for the BIOS space.
                          FPT Operation Failed.
                          so I used an external programmer and done it, me region still remains blank
                          also tried to install the ME driver from the last link you sent but also got error:
                          Win32 exception occurred!!
                          Error code: 0x4E24 (20004)
                          Error text: ''
                          Extended error text: 'Error in device matching'
                            • 21031
                            Do you have the full laptop model number,motherboard part number, PCH original and replacement part numbers
                            • rookieme
                              • Oct 2014
                              • 397
                              • Greece
                              sure
                              the model is GL72 6QF, MS-16J51 the motherboard and the PCH SR2C4 as the original one.
                              I'm thinking what piernov mentioned that it could be bad solder issue...
                                • 21031
                                sure
                                It could be a bad solder issue. Can you try one more thing please, run MeInfo from a dos bootable drive using the command MEInfo.exe -verbose .If the dos version doesn`t work then try the win64 and UEFI versions.
                                Attach a copy of the end of the report.
                                • rookieme
                                  • Oct 2014
                                  • 397
                                  • Greece
                                  I used the win version in order to copy the error, dos version gives save error.
                                    • 21031
                                    The errors are interesting,and after a bit of googling what all those errors mean i`m none the wiser. What bios chip part number do you currently have on the board ? ,can you try,or have you tried a different one.The only other thing i can suggest is trying an older bios version and if that doesn`t work reball or replace the PCH.
                                    https://download.msi.com/bos_exe/nb/E1795IMS.107.zip
                                    • rookieme
                                      • Oct 2014
                                      • 397
                                      • Greece
                                      old chip 25B6464CSIG, new QH64AHIG with 107 bios version same results
                                      next update will be after reballing with leaded balls
                                      • rookieme
                                        • Oct 2014
                                        • 397
                                        • Greece
                                        so I replaced the SB as I had one more but it does the very same thing
                                        I had enough of this one so it's time to let it go unrepaired
                                        I want to thank everyone of you for your time and effort to help me repair and learn
                                        • tom3k
                                          Dell Precision 5540. Need clean ME Region
                                          by tom3k
                                          Laptop: Dell Precision 5540
                                          MB: LA-H331P Rev: 1.0(A00)
                                          Hi.
                                          I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                                          After extracting my BIOS in FIT the ME Region size is 7565 KB.
                                          However the ME Region files I fouud online are 11688 KB in size.
                                          Can someone help me find he correct clean ME Region?
                                          Thanks!
                                          Code:
                                          ║ Family │ CSE ME ║
                                          06-28-2025, 12:34 PM
                                        • Adenitz
                                          Clean ME region - a bit of theory
                                          by Adenitz
                                          Hello laptop repair experts,
                                          can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
                                          I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
                                          What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
                                          Recently, I had a two cases where laptops (one is Lenovo Idepad...
                                          10-21-2023, 04:44 AM
                                        • Lexsmash85
                                          Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                                          by Lexsmash85
                                          Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                                          Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                                          USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                                          08-06-2025, 03:41 AM
                                        • konovalec85
                                          Clear me region Acer VERITON L670G Q45T-AS
                                          by konovalec85
                                          Hello
                                          Can someone help clean the ME region?
                                          I flashed the BIOS with this file and writes intel me unconfiguration in progress when loading
                                          I wanted to try to clean the region myself, but I don't know which and where to get a file with a clean region for this motherboard. And what version do I need?
                                          FITool 10.0.46.1002?
                                          Chipset * North Bridge – Intel Q45 * South Bridge – Intel ICH10...
                                          01-12-2025, 05:14 AM
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
