HP ZS050 LA-A994P, charging light, power led on for 1 second when power button pres
  • MobileXT
    • Oct 2012
    • 200
    I have a friend of mine that he gave me a HP-15 to repair. I didn't try fix any PC before but I did fixed a lot of macbook computer. That being said i'm a new to fix PC laptop. I don't even know where I start. The Mother board Parts number is ZS050 LA-A994P REV.2 2014-03-13. anyone can assist me I would greatly appreciate.
    Thanks,
    MobileXt
  • MobileXT
    • Oct 2012
    • 200
    Re: HP ZS050 LA-A994P, charging light, power led on for 1 second when power button pr
    Okay, I took some pictures where I did the measurement. I don't have schematic on this Version 2 I do have the version 1 but I'm not sure if that is the correct one. Please see attached photo and need some advice.
    • Sephir0th
      • Oct 2020
      • 1282
      What is the actual issue/behaviour of the Laptop? Please Tell us detailed as possible. However, 19V Rail seems fine. Share shematic Please and/or ask for Rev. 2 in Schematics Section. We have to inspect 3.3V and 5V.
      FairRepair on YouTube
      • MobileXT
        • Oct 2012
        • 200
        The actual issue is just don't turn on. The WIFI LED turn and CAPS lock ket when power button press. I don't have Voltage on the 3VALWP and 5VALWP using Schematic Ver. 1
        • MobileXT
          • Oct 2012
          • 200
          At PU301 pin 13 EC_ON voltage is present and PIN 11 also present 19v. It could be PU301 DEAD?
          Note I'm using LA-A994P Ver1 Schematic for now until i have the Ver.2
          • sopik78
            • Nov 2013
            • 517
            • Czech Republic
            Have you measured all power rails for short yet? If not, do it first. While you don't have 19V after second DC-in mosfet, there must be some issue.
            As far as I know these boards, I guess there could be shorted CPU. But do your own measurements.
            Edit: my mistake, PQ103 has 19V on both sides and 3V is for PQ104, which is correct.
            • MobileXT
              • Oct 2012
              • 200
              There's no shorted on the board
              • sopik78
                • Nov 2013
                • 517
                • Czech Republic
                +3VL generated? BIOS IC has VIN power?
                • MobileXT
                  • Oct 2012
                  • 200
                  I Will try measure this one I will report back . Also on PD2 I have 19V and 0.7V on the other PIN please see attached.
                  • MobileXT
                    • Oct 2012
                    • 200
                    Both BIOS IC have 1.8V and +3VL is also present
                    • sopik78
                      • Nov 2013
                      • 517
                      • Czech Republic
                      Both? I think there is only one 8MB SPI. Try to reflash BIOS, also EC.
                      • Sephir0th
                        • Oct 2020
                        • 1282
                        I asked you to Share your actual Schematics and of course, I Understand you're working With Revision 1 and suggested you to ask in Schematics Section for Rev. 2 and i Just saw you have opened a Thread there. Very good.
                        However, Better and faster Help Only possible with Schematics. Please Share it.
                        • MobileXT
                          • Oct 2012
                          • 200
                          Here is the LA-A994P Rev1 Schematic
                          [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...hematic-needed
                          • Sephir0th
                            • Oct 2020
                            • 1282
                            Share exact voltages of PU301 Pin 6,9,11,12,13,14,15,17 and measure Resistance to ground on PIN 9 and 17 with all Power removed.
                            Edit: 0.7V ADP_ID seems a little Bit Low, i think should be around 3 - 4V, but unfortunately i'm Not really experienced in HP devices. So can be meaningless, because you're getting EC_ON Signal, AS you Said before.
                            EDIT2: i have Just researched a Bit and believe 0.7V is okay.
                            • MobileXT
                              • Oct 2012
                              • 200
                              PU301 diode Mode (Red on Ground)
                              Pin 6= 0.522v
                              Pin 9=0.337v
                              Pin 11=0.467v
                              Pin 12=0.677v
                              Pin 13=0.525v
                              Pin 14=0.532v
                              Pin 15=0.459v
                              Pin 16=0.433v
                              PIN 17= 0.400V
                              PU301 Resistance to Ground (Black on Ground)
                              Pin 6= 26.20kΩ
                              Pin 9=16.45KΩ
                              Pin 11=23.40MΩ
                              Pin 12=99.0kΩ
                              Pin 13=O.LMΩ
                              Pin 14=265.5KΩ
                              Pin 15=47.8KΩ
                              Pin 16=26.20 kΩ
                              Pin 17 = 29.75KΩ
                              • MobileXT
                                • Oct 2012
                                • 200
                                I need to figure it out first on the PU301 why is not turning on. EC_ON is present and 19V VIN is present. Once I get this Power rail Running then I will go ahead on the BIOS Reflash.
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  Pin 6= 0.522v
                                  Pin 9=0.337v
                                  Pin 11=0.467v
                                  Pin 12=0.677v
                                  Pin 13=0.525v
                                  Pin 14=0.532v
                                  Pin 15=0.459v
                                  Pin 16=0.433v
                                  PIN 17= 0.400V
                                  Pin 6= 26.20kΩ
                                  Pin 9=16.45KΩ
                                  Pin 11=23.40MΩ
                                  Pin 12=99.0kΩ
                                  Pin 13=O.LMΩ
                                  Pin 14=265.5KΩ
                                  Pin 15=47.8KΩ
                                  Pin 16=26.20 kΩ
                                  Pin 17 = 29.75KΩ
                                  Mhm, i don't know whether it is my "bad" english or not, but i wanted to ask you to share the voltages when Adapter is plugged (DC-Mode, Red Probe on PinX and Black Probe on Ground). But the resistances are looking fine.
                                  • MobileXT
                                    • Oct 2012
                                    • 200
                                    PU301 POWER Adapter Plug-in Voltage Measurements.
                                    Pin 6= 3.42v
                                    Pin 9=3.43v
                                    Pin 11=20v
                                    Pin 12=3.324v
                                    Pin 13=3.302v
                                    Pin 14=5v
                                    Pin 15=3.3v
                                    Pin 16=3.3v
                                    Pin 17 =5.21v
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      All the reading seems good but still you dont have 3Valwp/5valwp. You need to check entrip1/2 and fb(feedback) pins as these two signals decide whether you will have output on coils or not. Bios corruption is a possibility-so do flash bios first.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1282
                                        Sorry for interposing a bit, but would you explain this for me, please. I'm actually asking myself how it can be a BIOS issue, if the SPI not getting its +1.8VALW on Pin8 in this Case? Actually I have a similar case (5VALW present, but no 3VALW, SY8286BRAC, known for often failing) and if this is true, maybe there is a chance to bring it back to life by simply flashing the BIOS. I just want to understand this behaviour, if this is true.
                                        Greetings
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          Laptop computer that went completely dead no boot no power light no hard drive light
                                          by sam_sam_sam
                                          See pictures for type of laptop computer
                                          I checked switching power supply brick 19.2 volts multi meter only
                                          No booting without switching power supply connected
                                          Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                          What the heck is going on here...
                                          04-04-2025, 04:58 AM
