Got a 42" Vizio Plasma TV. Original Owner says there was a loud pop and then the screen went dark. Simple searching around has shown this a common problem. Recommendation is to replace y-sus, z-sus and control board at the same time... thats not gonna happen on my budget. I'm not fixing this TV for anybody nor am I fixing it to resale it... this is simply for fun
Anyways, I opened her up and found that there was a swollen cap on both the y sus and z sus boards. The the cap on the y sus board is swollen badly... the pictures I've included don't really do it justice as I took them from the wrong angle.
The main fuse on the y sus board is open (it fuses the incoming Vs that is fed from the power supply). A continuity test shows there is a direct short between Vs and Ground... I checked all the major components (besides the IPM) and cannot find where the short is, but I suspect its the IPM module. I'm just waiting for an order of chip quick to arrive so I can remove it for a better look/test.
I'm also getting a esr meter in a few days as well... I want to check the various caps throughout the TV as they are mostly samwha's circa 2004.
Nothing appears wrong with the z-sus board except that one of the same types of cap is swelling on the top as well. Vs input fuse is still good and no short from Vs to ground as there is on the y-sus. Hopefully there is nothing wrong with the z sus board aside from the swollen cap.
Swollen caps are Samwha HK 250V 680uF
Pictures are of the y sus board. The swollen samwha is in parallel with another identical cap. These caps are installed across Vs and ground.
